Who is still using a rubber mount?
Any 11, 10 second cars still on the rubber tranny mounts? I don't hear of a lot of them breaking under the 4L60E but a lot of people change them anyway. Just wondering if I really need them or if I should switch back to smooth out my ride again.
I guess it's a moot point at this rate to swap back to the stock one for smoothness seeing that my lca's, phb and torque arm all have poly bushings.
I think after my suspension is fully done in the spring, I will see how it is once everything is dialed in right and all the angles are correct. If I can't get it smoothened out I may try the rubber mount. I have a fairly new, ~5k mile mount in the garage to use.
Didn't smooth out anything at all really. At that point with the poly torque arm mount and the rear suspension bushings being poly the car felt the same with the new rubber mount compared to the well broken in poly.
To clear things up for me one of my friends tried it too (with the exception of him having aftermarket shocks in the mix) and at that point noticed no difference in going back to the stock mount. Now had we had the stock suspension/chassis pieces back in place there would be a difference.
There was a member on here a while back that took a stock GM mount and filled the holes with some type of either silicone or strong adhesive. This made the mount more durable and would resist tearing but would allow some flex. He had pics of it (it was at least two years ago). He swore he could launch HARD and not damage his trans mount and wouldn't ever go back to a poly mount again.
Wish i could dig that thread up....
Oh, and you don't need to hit bumps in the road for upgraded suspension parts to become noticeable, it's very apparent on smooth roads too.
FWIW, my pinion angle is at -2 and I forgot to mention poly endlink bushings front and rear.
Just trying to help out and hopefully more people with experience can chime in.
Probably used windshield urethane to fill the mount. Comes in a tube like caulk. Very firm, but not as firm as poly. Tape one side of the holes shut, just start filling it. Takes FOREVER to set completely! Don't expect to squirt it in there and bolt the mount back on in an hour or two.
