Quick shifts off the line only at WOT
The trans is a built vacuum modulated 4L60E with a Yank SS4000 converter. I've messed around with the shift pressure modifiers with HP tuners, although I'm not sure if that's going to have any effect with the vacuum modulator installed. I basically took a stock Z06 vette tune and transplanted the shift tables onto mine. I haven't flashed the tune yet to test it out.
Has anyone else dealt with an issue like this before?
daniel6718 - It's actually shifting into 3rd gear, not locking into 2nd
Performabuilt - One thing I noticed that was a bit peculiar is that the TPS readings displayed in my Tech 2 never went above 99% in the transmission data. In engine data display, it showed 100%. The actual TPS voltage displayed in both engine data and transmission data was the same. However I wouldn't think this would make any difference because the PCM is programmed (according to HPTuners) to use the WOT shift tables anywhere above 93% TP. Aside from that, the part throttle shift tables are the same from 90% up.
