hitting the rev limiter
Old Nov 22, 2006 | 01:17 AM
camsom's Avatar
Default hitting the rev limiter
hey guys need some help got a yank 4400 PT its been in for about 2 weeks got it tuned and am having trouble with it hitting the rev limiter checked fluid levels was wondering if i need to get it re tuned or maybe there is something i am missing any help would be appreciated thank you
Old Nov 22, 2006 | 11:22 AM
bjamick's Avatar
get whoever tuned it to raise the rev limiter up a lil more and set your tranny to shift at a certain RPM under WOT.
Old Nov 23, 2006 | 07:38 AM
MICAH HERRON's Avatar
From: Johnsonville, SC; but orginally from GAINESVILLE, FL
Agree with the post above. Tuning is the issue, bumping up the limiter and adjusting the tranny a little will fix it. Your tuner should know exactly what to do to fix that.
Old Nov 23, 2006 | 04:11 PM
AK's WS6's Avatar
Yep. I still don't have mine tuned (it's been over a year..lol) and I have the same problem on the 2-3 shift.
Old Nov 23, 2006 | 04:54 PM
sleeperstyle's Avatar
don't touch the rpms, adjust the mph tables. also the shift time to like .2 or so is a good start- don't remember the exact table but if you look it will be obvious.
for the car to shift it has to hit BOTH the rpm and the mph threshhold. the last one it hits will make the car shift. if it hits the rpm threshhold and still didn't satisfy the mph it won't shift, and you hitting the limiter probably means it STILL didn't hit the desired mph and the limiter came into play.
on the juice i had my mph tables conciderably lower than on motor, since it pulled more rpms at a given mph.
