Converter installed today, what's wrong?
Not shifting into OD doesn't sound good, though.
A 3600 will slip a good bit. Giving it light-moderate gas you should turn ~2,500 rpm while accelerating. That is where my 3500 stall speed, 2.5STR TCI ran.
Ah yes, good point.
Can you tell the difference?
A stalled car may run similer RPMs not locking up in OD as locked in D.
if it still doesn't work you may be looking at a burnt up lockup clutch, or a bad lockup solenoid. the clutches do seem to go bad more than people think. that is why i ran the multi-disk converter
, not gonna burn up 3 clutches but didn't have a problem burning up the single's more than once. (component slipping) code. Immature P1870 will
make it quit trying to lock. A couple of P1870s to
get the SES light on. P1870 after key off / key on
will again attempt lockup.
After beating on it with no trans cooler you may
have either gotten the trans so hot it is making
inadequate pressure, or pushed it into the Hot
shift tables.
