Here’s some info I found about running in OD while Drag Racing.
#41
Originally Posted by L36Camaro
I’ll launch it in D and bump it into OD after the 1-2 shift at the Drag Strip.
what would be the difference in launching from od and launching from 3?
#44
Originally Posted by BlackHawk T/A
I'm willing to bet you can't get your shift points any closer yourself. You can try though ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
The problem is, it won't shift right when you tell it to.
#45
Originally Posted by performabuilt
you can note thats its on in this link,
www.performabuiltautomatics.com/dthird.html
and you can note in this one below that it does not come on during the 2-3 shift in the OD position
www.performabuiltautomatics.com/odthird.html
just a little information .
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
#48
Originally Posted by Raise
but if you will be bumping it back up to od anyway, why start in 3 just for the launch? wont u be starting in first gear either way?
#52
Originally Posted by The Elimi8tor Z28
I hear it’s better to drag race the car in OD, because in D the over run clutch is on and it decreases the line pressure in the 2-3 shift point, and in time they say it may contribute to 3-4 clutch failure.
Example:
So is this true???
I’m thinking I should run my car in OD in all conditions. Because in Pontiacs it goes (1, 2, 3, D), so OD in Camaro’s is really “Drive“.
I don’t think it will hurt anything running my car in OD all the time.
What do you guys think about all this???![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Example:
So is this true???
Mec
#53
You guys are making this way too complicated. If it's gonna break, it's gonna break.
FWIW, I just drove my car 150+ miles to the track, cut 1.6x 60's ran 11.0 and turned around and drove it back, w/ a bone stock trans, in D, no OD. I always drive around town in D also.
#54
[QUOTE=Red2000SS]2.73 gears make for a high ratio - I ran the numbers through one of the gear calculators on the web. Assuming a shift point of 6000rpm here is were each gear would top out:
1st: 55
2nd: 104
3rd: 168
4th: 240
those numbers seem realllllll high... i leave it in D every time i race and im at between 4000-5000rpm at the end of the 1/4
1st: 55
2nd: 104
3rd: 168
4th: 240
#55
LS1Tech Administrator
Received 1,668 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I'm staying in OD 100% of the time. With a tune you can get it to do exactly what you want as far as lockup and shift points go.
Plus my car doesn't like to kickdown from 3-2.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#57
Originally Posted by Dan
I am really confused, I have been drag racing a long time & always keep the Shifter in 3rd, So is this the (D) you are talking about? Since I have 1,2,3, D
#58
Alrighty how bout this one guys..... What happens to line pressure on this dreaded D, 2-3 shift with a vacuum modulator? All rules still apply or will line pressure in this case be different?
