Lazy Lock-Up??
g
No trans expert, but just something I have noticed
And yes, we did see much less TCC failure prior to seeing TCC PWM management software. Think about it, if the clutch piston is being fed pressure on a PW then it only stands to reason that the clutch is slipping, and if the clutch is slipping then it is generating heat. If then that clutch is in a car that does not have adequate cooling capabilities then it is going to burn prematurely, simple fact.
I would argue that in the example of a converter only swap, most of the cars did not get a external aftermarket cooler. And those transmissions/converters died because of the excessive heat generated by the new converter being in a stall condition most of the time because it "felt great" to leave it in 3rd gear while cruising.
But conversely, if a bad *** transmission and converter were purchased, then that investment was most likely protected with a much improved cooling system. And that contributed to the longetivety of the combination. Not necesarily the PWM strategy and hydraulics modifications.
I am not arguing the PWM elimination, hydraulics massage issue at all. It is a well known fact that if line pressure is increased then overall durability is improved, on any unit. And it only makes sense that if the converter clutch is not on a PWM but an on/off strategy it will last much much longer.
Again though, I believe the symptoms described in this thread are normal operating conditions for a 4l60E converter lock-up strategy. But, I could be wrong. Just my opinions.
g
If you have a scan tool and a buddy, take a test drive and command the TCC on (both solenoids to ON/100%) and off several times; this overrides what the tune would command, so you should be able to see if there's any difference; if there's no difference, then one of the solenoids could be slow or leaking or partly failing somehow, or the TCC is failing; if there is a difference, then the problem would be in the tune.
We also remove the check ball from the input shaft if we have the unit on the bench.
back to the original question though.... was this vehicle repaired? If so what did it?
g
g
