using a v6 trans with an ls1
Old Apr 30, 2007 | 03:00 PM
chevrev's Avatar
Default using a v6 trans with an ls1
can a 4L60e from a V6 (3.8L) application be adapted for use with an LS1? i am curious if i can replace the bellhousing to match the bolt holes of the LS1 and also if the internals of a 4L60e (out of a V6 3.8L) are built to handle/operate properly behind an ls1.
thanks!
Old Apr 30, 2007 | 03:32 PM
GregWS6&z28's Avatar
no, the input shaft splines are a different count and would require a different converter. not worth the hassle. just find the right trans from a junkyard or something.
Old May 2, 2007 | 01:51 AM
performabuilt's Avatar
LS1Tech Sponsor
As he said the input shaft is different but also the stator is different for the pump. Though it could be modified to do it I am not sure it would be worth the effort unless the trans was incredibly cheap price wise
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
