Powerglide vs TH350
Originally Posted by Dzman
Ummmm I may be nuts but atleast I can read!!!!!I could give 2 ***** about how streeable the car is for the the 90th time read the post and u could see that.....Ok did u know a stock lt makes 250rwhp add 100 150 shot thats 360 rwhp easy ok plus I have some bolt ons.Spend 700 on a verter when I can have a tranny done for the same with hardened sprag,Kavlar bands,tci vavle body and some more stuff and it takes less power to turn the glide tell me why I would wanna stay with a 4l60e?
Originally Posted by ChocoTaco369
wow, easy there, partner. cool your jets, mavrick. if you listened, you'll also perform better with a 4L60E. the ratios are better, meaning you'll accelerate faster. also, you should put more power down. plus you'll have more gears for the added trap speed. if you gear your car aggressively with a TH-350 or TH-400, you could run out of gear. with a 4L60E, even with 4.56's you can go well over 100 mph. try doing that with a TH-series.
EEEEEEEEEE damn but then the car would NEVER hook up bc of the ratios plus u did forget to add in the how the 4l60e would cost over twice as much to build
360rwhp? sorry man, i think you're nuts for not just opting for a built 4L60E. 360 rwhp is nothing for a properly built 4L60E. plus, you get overdrive, less drivetrain loss and better ratios than a TH-350, TH-400 or glide.
does the powerglide take away rwhp like t400 does on the dyno??
Question is do you want to drive the car or look at in the yard
4L60Es are capable transmission, very much so ,
the funny thing is if people only knew the similarities between a th350 and a 4l60e , Its not a matter of parts though they are important but more a matter
of build
of build
__________________
you can get a tranny from a sponsor with an aftermarket stall for ~$2000. when you factor in the cost of a TH-350 or TH-400 plus all the equipment and labor required in modifying the car so it'll fit, the prices come out similarly. you have to remember that the car needs to be modified to fit the TH-series, and that costs money in parts and labor.
Notch the stock cross,I have the TA arm bracket from my old camaro so I can reuse my old TA arm and going to take some measurements so I can see witch turbo350 tailshaft I will need 2 use the stock driveshaft. Well under a 1,000 and I will deff be doing the work myself.Also a 4l60e wont make a car a DD 4400 stall 4.10 gears=no fun in rush hour no matter what tranny
Originally Posted by 2003CobraKB
i totally agree with this guy...if u have 600-1000hp then can go with the powerglide or t400...
A glide is very lightweight and so are the internals. It's supposed to be very efficient compared to aa th400. How much so, I'm not sure.
Mine works great though and I can't wait to hit it with 150-300hp.
I've been 11.30's in a 3400lb car, 3.73's, 28" tires, 5000 stall. It drives ok on the street also.
I've been 11.30's in a 3400lb car, 3.73's, 28" tires, 5000 stall. It drives ok on the street also.Just ok..... I DD my Turbo/Glide car... no problems at all...... I love it...
350, gear, glide, high, port, powerglide, proformabuilt, ratio, speed, t350, th350, th400, tranmission, transmission, vs
