Not your normal problem!?!
I have just installed my motor and trans back in the car after letting it sit for about a year and a half (child) and when I went to start the car the tires started to move. I had it up on jackstands and when I saw that I made sure that it was in park and it was. So I tried it in N and it did the same thing. Every Gear was the same. Any help would be great! Thanks. Buck
if it does then the trans end of the linkage is ok ,Then you will need someone to help you determine if the cable is moving correctly
I have to say that it is very cool to have a Sponsor giving me advice on what to look for. Thank you , Buck
Same thing PBT said only different.
g
