2-3 shift problem with 85mm MAF?
Old Jul 29, 2002 | 09:47 PM
h53speed's Avatar
Default 2-3 shift problem with 85mm MAF?
How many of you have had a problem shifting to 3rd in D with the 85mm sensor?
Old Jul 29, 2002 | 09:59 PM
ShooterSS's Avatar
Default Re: 2-3 shift problem with 85mm MAF?
I have the Pace LS6 MAF and no problems.
Are you sure it's not Torque Management?
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 29, 2002 | 11:06 PM
BriguyLS1's Avatar
what kind of problem are you having in 3rd gear? beacause I am haveing a problem shifting into 3rd gear also but i dont think that related. sometimes for me it doesnt wanto go in gear and other times when you get on the gas it will go in... is this the same problem your having?
Old Jul 30, 2002 | 07:41 AM
h53speed's Avatar
Yeah, right now it shifts into 3rd fine in everday operation and in WOT it seems to flash from 5000 RPM to 6000 hit the limiter and then shift. I am going to try programming the HPP3 with an oversize tire height as I have heard of problems with the 99's. If that doesn't work I will put the stock MAF back in and see if that will fix the problem... I'll get back with you...
