What causes A4's to break?
i asked a builder once, "would your 700 hp transmission take the torque of a cam/head, 4400 stall and nitrous?" my answer,"i dont know, buy our top of the line transmission"
so even later on when i drop the stall down to 3500 and put on a turbo, my torque output is going to be more than h/c, stall, n20.
a stall usually multiples tq. and that turns in the transmission. all the parts in the transmission turn. there for the force acting on a transmission is torque.
there are parts out there to allow you to spin your transmission and hold up past 6800. and besides im not looking to spin 7800 rpms. im looking for 6800-7100. and at that, im looking to hold something around ~450-470 tq to the ground (stock stall) and putting it with my 4400 tci 2.8 str stall and something around 150 shot of n20 (measured at the ground) without the stall you are looking for something around 500+ ft lbs of tq. and we all know 150 hp of nitrous is more that 150 tq b/c all forced induction adds torque - horse power is a by product that people "can under stand"
hp and torque as a combined enity by twisting tearing up hard parts and clutches which is why these are upgraded in Built units ,
RPM though as mentioned Presure loss and resulting clutch slip due to pump slide colapsing pump and additionally loss of lube for the same reason in a poorly prepared or stock pump.
Heat unless very very excessive while a killer to is a minor player in the short term .
Addressing why people dont mention torque in power handling it is subjective .
for instance and engine with 400 ft lbs torque at the crank with a converter that has a 2.0 for instance STR at a given RPM may send 800 ft lbs of torque to the trans for a breif period where as the true torque of the engine is still only 400 ft lbs if measured on the dyno with the lockup clutch applied
Hope this helps wish I had a thread about our transmissions saying good things running this long lol
Perhaps I should rename our sale today as PerformaBuilt One day sale and what kills and trans and what we do to stop it lol
horsepower = torque*RPM / 5250
if the horsepower is in the 500's, the torque in a pushrod V8 must be somewhat high also.
i'm still saying that RPM's are a bigger killer to the 4L60E than torque is. 500 ft-lbs of torque at 4,000 RPM's isn't nearly as deadly as 400 ft-lbs of torque at 6500 RPM's.
From a mechanical standpoint, there is a remedy to make a 4L60E withstand a certain amount of HP, Torque, and RPM's over factory ratings. What I have read about this slide spring replacement is that there is a spring good for 5500+ rpm. Doesn't elaborate as to how high it is good to, but then again all trannies have different tolerances and thus, will vary. Take this with a grain of salt, but to say that the main killer of a 4L60E or any other type of tranny is RPM's makes you sound mechanically uneducated.
I am everything shy of ASE certified and have enjoyed mechanic work for 12 years. I have rebuilt engines and done from off restorations. I have rebuilt manual trannies, but never automatics. I am crossing all my T's and dotting all of my I's before I start on mine. I will certainly post my results, even if I **** up my rebuild, which will be costly, but I am willing to take my chances b/c I feel that I am capable. The only thing that I am hoping for is a full racing season of mid to high 10 sec 1/4 mile passes out of the tranny that I am building.
but not all torque is equal. torque produced down low isn't nearly as deadly as torque produced up high. it's all about where the torque is contained. stock 4L60E's can handle torque down low.
i'm still sticking with the idea that high RPM's are dangerous to any 4L60E, no matter how heavily built. i'm sure it's doable, but it's very difficult. this is why so many 4L60E builds fail.
i am automotive tech. i have been doing this for about 10 years. my buddies and i always throw around ideas and theories about car stuff.
but let me guess, you dont build transmissions do you? you are not an engineer are you?
every thing affects the trans. its just not one thing. they all add up. but forget rpms. we can fix that, i wanna know how much tq they will hold. and that should be everyone else question.
(yes, I'm bringing it back to life)
think of when the 4L60E shifts during WOT. it'll shift from 6,000 RPM's, then go into the next gear at ~4,000 RPM's. it falls ~2,000 RPM's and then slams into gear. well, what happens when you raise the shift points 500 RPM's? the car falls 2,500 RPM's and slams into gear. the gears are being slammed 25% harder just from that 500 RPM increase. raise the shifts to 7,000 RPM's and you increased the stress of every WOT shift 50%. even if we assume the pump is indestructible, you're still slamming the internals a lot harder. this is one of my favorite quotes:
now, we also have to mention that the pump still isn't indestructible, and the higher you spin the RPM's, the more pressure is demanded to keep the clutches safe. in real life, the pressure is not exact every time. mechanical parts are prone to error just like humans and the line pressure isn't constant every shift. it's just not possible. all you need is one slip, one slight malfunction, one air bubble in the line, anything - and you have toasted clutches. the fact is, the higher the RPM you go, the bigger the risk of your tranny grenading is. again, 500 ft-lbs of torque being burdened on the transmission at 4,000 RPM's isn't nearly as dangerous as 450 ft-lbs of torque being burdened on the transmission at 6,800 RPM's.
again, i'm not a professional, this is all my theory. i'm a theorist, this is what i do. all i can tell you is, what i'm saying tends to happen. it's a fact that 4L60E's with raised shift points blow up more and faster, even when built.
now, some people may be thinking "okay, just throw on a torque converter to raise your shift extensions. then the RPM's won't fall as great during each shift. well, that opens up a whole new can of worms. aftermarket converters have a higher STR and apply even more torque to the transmission. while the shift extension may be better in terms of slamming the planets or any other part, you're still slamming with an even greater torque than stock, so it kind of negates the effect.
Attached are graphs I did from data on the SuperYank during a testing program. It's pretty old, but it gives you an idea of torque multiplication curves. BTW, the SY had a long torque multiplication curve for a 3500.
Input shaft
Sunshell:
I know that there is more damage when I get the rest of it apart.....
If anyone is interested, I can email a copy of my tune. My mods are Hooker LT, ORY, !air, !egr, 4.11 gears, and a 125 hp nitrous shot. Tranny did have billet servos, but problems were there before the servos were installed. Shift points were set 1-2 6000 rpm, 2-3 5900 rpm, 3-4 5900 rpm. I tried lowering the mph to dial in my shift points. The 2-3 shift was a rev limiter banger (6400 rpm). Tranny took a dump on a 20-25 mph roll flooring the gas pedal. With 4.11 gears it was in 4th on the coast and downshifted to 1st and I was surprised with the big BOOM. Put arear on jackstands and ran it through the gears and it returned to drivable (damage was done, things were bent inside). Did the roll punch a couple of weeks later and it did the tranny in to what you see in the pics. Tranny did break all motor on blacktop pavement and didn't hook. Fastest all motor run with stock converter was a 13.02 in the 1/4. 11.73 with a 125 hp shot.
