Trans guys please help,wierd noise.
Old Dec 9, 2006 | 04:33 PM
SPRAYED 01's Avatar
Default Trans guys please help,wierd noise.
I was driving the car today,pulled it into my shop for a wash and i start hearing a really loud sqealing noise.
Sound just like a loose serpentine belt but times 2. Its coming from the frt of the trans.
The car still feels exactly the same,fluid looks fine,temp is okay, just a loud *** squealing from the frt of trans.
Could this be the frt pump? If so how can i make sure before i start replacing stuff.Also the noise goes away after 3k when driving.
Dr evil stage III with 4k on it.
Yank SS 4000 with 1500miles on it.
I checked all the obvious,belts accessories,fans.
Old Dec 9, 2006 | 07:16 PM
SPRAYED 01's Avatar
Comon, where are all the trans sponsors??
Old Dec 9, 2006 | 07:39 PM
FLT's Avatar
FLT
PM sent.
Old Dec 9, 2006 | 08:11 PM
performabuilt's Avatar
LS1Tech Sponsor
Im not sue this is something i could help you with in the forum since it would take a more detailed description however you are welcome to call me at 5705785686 up untill "1 am "and anytime after 9 am every day and i will do my best to help you , even tonight
thanks
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 9, 2006 | 08:32 PM
LS1Tech Sponsor
Ok Im just going to post this so others can see too, I just got off the phone with this gentleman
1- the squeal he has comes from the bellhousing area,
2- seems to diminsh over 3000 rpm and I beleave he has a 4000 stall he said
3-it still makes the noise in drive brakes applied not moving,
4-when you turn the car off the noise continues for 2-3 seconds then it to stops ,
Here what it cant be
1- it cant be internal to the trans because when in gear brake applied nothing in trans is moving
2- it cant be the pump because it continues after you turn the car off for 2-3 seconds and the pump stops with the engine
I gave him one possibility and suggested he contact the converter manufacturer but this is a strange thing so wanted to put this information out there for others and see what everyone else thinks to
__________________
Call 888-744-6542
Old Dec 9, 2006 | 10:38 PM
SPRAYED 01's Avatar
Anyone else ever encounter this?
Old Dec 10, 2006 | 07:25 AM
B.Buster's Avatar
Sprayed, I had a similar prob only it was on a manual trans. I thought it was the throwout bearing.Turns out it was in the PCV system . Long story short try removing the oil cap and see if it goes away.
Old Dec 10, 2006 | 10:15 AM
SPRAYED 01's Avatar
Thats strange for the pcv to make that noise. The really strange part is that right before the noise the only thing i did to the car was remove my breathers and install a catch can.
I cant get to the car today but im going to remove the oil cap tommarow.
Old Dec 10, 2006 | 10:18 AM
LS1Tech Sponsor
actually it would explain some things like why the sound continues for a couple seconds as the vacume bleeds off
__________________
Call 888-744-6542
Old Dec 10, 2006 | 10:35 AM
SPRAYED 01's Avatar
If this is the cause im really going to have to think twice next time im about to replace
an expensive part trying to diagnose something.
Old Dec 10, 2006 | 11:18 AM
LS1Tech Sponsor
its always good to get second opinions and review all the possibilities . thats why I reposted the additional information for you
__________________
Call 888-744-6542
Old Dec 10, 2006 | 11:22 AM
SPRAYED 01's Avatar
Thanks a lot performabuilt, its nice to have a sponsor that will help you out even if its not their product with the problem. Your reputation around here is great and now i know first hand. Ill keep every one posted on the situation.
Old Dec 10, 2006 | 01:41 PM
B.Buster's Avatar
Sprayed , this is the long version. The hose coming from the TB to the valve cover had kink not letting fresh air to the PVC system. As I drove (mostly during decelleration) the vacuum inside the block would get high.Air would suck in around the dipstick and any place else it could. This made a high pitch squeal that sounded like a fan belt on a seized alternater. It was so loud that it could heard a block away. It was hard to figure out where the noise was coming from . Mine was also intermitent making it that much harder. Good luck.
Old Dec 10, 2006 | 04:09 PM
SPRAYED 01's Avatar
Wow that is really weird. I have the port on tb and valve cover blocked off. Im running
a catch can from the port on the intake to the line that used to go to the intake thats hooked up to the rear of the driver valve cover. I guess ill start looking for kinks in lines. I also was having a sticking idle and the noise would go away if i held it about 3k. All that would indicate a vacum problem. Cant wait to try this stuff on monday.
Old Dec 10, 2006 | 04:48 PM
FLT's Avatar
FLT
Sounds like you found your problem. Good luck, Vince.
Old Dec 10, 2006 | 06:19 PM
SPRAYED 01's Avatar
Not sure yet ill let you guys know. Thanks Vince.
Old Dec 11, 2006 | 02:43 PM
SPRAYED 01's Avatar
Alright, i figured it out. It was the pcv system. I had installed a catch can right before the noise. I hooked it up to the intake vacum port and to the line that connects the two valve covers. I guess this caused a loud vacum sucking noise
that sounded just like a belt or bearing that went bad.. Weird but true.
