trans temp gauge
I have been told that anywhere around your coolant temp is fine....but my buddies TH400 turbo car with a 3600 stall and a giant cooler never gets much above 140.
I have my sender in a custom t-junction into the exiting coolant lines of the trans. Very accurate. Much more accurate than the pressure port on the driver's side of the trans.
+1
This will give you an idea. I posted this up a few months ago. It works great and my temps are spot on with GoFast908Z's.
I dont' knwo the size, but if you have your temp sender with you, you could always test fit standing in the store like I always do...
Exactly...how cool the temp gets means nothing to me. I simply want to know the hottest temps my tranny ever sees and this is the way to tell that. I don't remember the dimensions on the T-fitting. For ***** and giggles, I did this same thing for my water temp gauge since the sending unit is exactly the same as the one for the trans temp gauge. I used the T-fitting to do the TB bypass killing two birds with one stone. Pretty amazing how much difference there is in the displayed water temp on the factory gauge and the aftermarket one. Factory reads 210* all the time, aftermarket fluctuates between 180*-210*. I was supposed to get pics of that as well but haven't had a chance yet.
