TH400 and a working speedometer???
Old Aug 5, 2002 | 07:09 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Default TH400 and a working speedometer???
I finished up my TH400 install last weekend and the only thing I haven't done as of yet is to hook up the speedo. I can't see spending ~$250.00 for Yanks piece. Nothing against Yank at all. It just seems mighty high.
Someone told me that there may be a much cheaper route using all GM parts/pieces. Anyone know of this?
What else have people done OTHER than the Yank part?
Tim
Old Aug 5, 2002 | 07:18 PM
RyanJ's Avatar
SSU Moderator
Default Re: TH400 and a working speedometer???
its a part from a mid 80's GM truck. email Matt98SS. he used this part in his 400 install and may be able to give you a part number.
Old Aug 5, 2002 | 07:29 PM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan:
<strong>its a part from a mid 80's GM truck. email Matt98SS. he used this part in his 400 install and may be able to give you a part number.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks Ryan. Do you know his member #?, cause you have to search by a damn member # rather than by a name. WTF???????
Tim
Old Aug 5, 2002 | 07:48 PM
chevyguy3's Avatar
do the LS1s still use a 40 tooth reluctor? i have both the reluctor and sensor to use to make a th400 work with an LT1 speedometer. makes it work perfect in Auto cars(they origionally had 40 tooth reluctors). 6 speed cars have to have an A4 file with all the tranny funtions disabled to use it, but there is no option to make the tranny work with a 6 speed PCM file in LT1 cars.
if LS1s are the same way, i bought my sensor and reluctor from Sam Smith (cheapest place i know of to get GM parts). they are brand new and still in the sealed plastic. ill sell them for a small loss
dn95formula@aol.com
Old Aug 5, 2002 | 07:50 PM
chevyguy3's Avatar
part #s are
reluctor ring- 8655291
sensor- 8655315
Old Aug 5, 2002 | 08:05 PM
Tim98TA's Avatar
Sounds like a good deal. Does this just plug right into the original LS1 harness.
I'm not sure about the reluctar, but I will do some searching.
Thanks,
Tim
Old Aug 6, 2002 | 09:33 PM
Tim98TA's Avatar
I did some searching and everything I saw said 40 tooth reluctor wheel. Course NONE said anything LS1 specific.
chevy guy, you have mail.
Tim
Old Jul 1, 2008 | 06:00 PM
BIG BAD BLACKSS's Avatar
Originally Posted by chevyguy3
part #s are
sensor- 8655315
Dragging up an old post but theres some bad info quoted here that I just found while doing a search, dont want anyone having any problems.
The part #s are reversed. It should be,
reluctor ring- 8655315
sensor- 8655291
Sensor is showing a revised part # of 2133513 according to a non-vendor website. Anyone looking to buy one can check into that more.
Old Jul 2, 2008 | 11:32 AM
9000th01ss's Avatar
Yea, there are also two reluctor wheels depending on what size output shaft you have. 32 spline is one size and 27 spline is another.
Yanks tailhousing I'm assuming has a TA mount? I see no other reason for the need to change the tail housing.
You need a chassis mountned TA to use all GM stuff witht he stock tail.
