Auto behind a LS7
Old Dec 19, 2006 | 11:31 PM
GMRACER13's Avatar
Originally Posted by ss dave
So you would have to take all the electronics from a a 07 corvette, caddy etc. if I understand correctly. Dang. Ok I'll just manually shift it with my B&M.
I didn't know that B&M made a shifter with enough gates for a 6 speed auto. Or are you planning on running two B&M three speed shifters possibly a 4 speed shifter and a 2 speed Powerglide shifter?
Old Dec 19, 2006 | 11:35 PM
ABeasst's Avatar
Why not a good ole 4l80
Old Dec 19, 2006 | 11:58 PM
ss dave's Avatar
Just kidding about B&M but I hadn't thought of the two shifter set-up, 4l80e would require too much surgery.
Old Dec 20, 2006 | 12:29 AM
GMRACER13's Avatar
Why would a 4L80E require too much surgery? If you can put a TH400 in a '69 Camaro you should be able to put a 4L80E in one. A 4L80E is an overdrive version of the TH400. It's the same transmission just a little longer. Does the tunnel get too narrow at the end? You could always go with a T-56 6 speed manual.
Old Dec 20, 2006 | 01:49 AM
performabuilt's Avatar
LS1Tech Sponsor
I'm not sure there is presently a manual setup for one of these anywhere , it would definatley have to be done from the valve body since the ecm is inside the trans ,
And even then I'm not sure gm even made 6 positions on the gate for the shifter which would complicate things more ,I will do some studying on it but theres not much available yet that I can find .
As for now your best bet economically and performance wise would be a built 4l60e
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 25, 2006 | 05:12 PM
slimcracka's Avatar
th400 with a big nasty converter FTW!
