A4 Problem
Old Dec 20, 2006 | 09:30 AM
tdwta2001's Avatar
Default A4 Problem
.if you punchTHE CAR FROM AROUND 45 OR SO it it drops down to 2 and revs up so fast it bumps the rev ans it feels like it slips .so i man put it in first give it quick hits on the throttle car jumps nice put it in second going a bit faster to get rpms up and do the same quick hits on the throttle and it slips then catches after a second almost feels like your spinning.this is the only gears doing it..please give me some ideas on this one.
thanks
Old Dec 20, 2006 | 10:09 AM
Magnet's Avatar
i dont know too much, but it sounds like tis going out
Old Dec 20, 2006 | 10:32 AM
performabuilt's Avatar
LS1Tech Sponsor
could be the band is failing burned , How many miles on the trans ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 20, 2006 | 11:50 AM
tdwta2001's Avatar
has only 31000 on it .its a 2002 trans am
Old Dec 21, 2006 | 12:28 AM
LS1Tech Sponsor
Thats pretty low unless its been beat to death, are there any codes or ses lights
__________________
Call 888-744-6542
Old Dec 21, 2006 | 01:06 PM
tdwta2001's Avatar
no codes at all
Old Dec 21, 2006 | 01:10 PM
LS1Tech Sponsor
I would still have to go with the band though you may want to at least check the 2nd accumulator spring
__________________
Call 888-744-6542
Old Dec 21, 2006 | 09:18 PM
tdwta2001's Avatar
how do i find that spring?is it something i can do as a novice
Old Dec 21, 2006 | 09:30 PM
LS1Tech Sponsor
yes drop the pan in the rear corner you will see and aluminum part with three 10mm bolts then remove it then remove the piston from inside it and inspect the springs
thanks
__________________
Call 888-744-6542
Old Dec 22, 2006 | 11:31 AM
tdwta2001's Avatar
thankyou i will check it..
Old Dec 22, 2006 | 12:51 PM
zspot98's Avatar
Damn Terry if it's not one thing with you it's another. Maybe that trans didn't like sitting behind that 383?
Old Dec 22, 2006 | 01:02 PM
'Trust''s Avatar
A stock tranny behind a 383? That explains it!
Old Dec 26, 2006 | 11:00 PM
tdwta2001's Avatar
gonna change fluid and filter again and hope for the best
Old Dec 26, 2006 | 11:08 PM
LS1Tech Sponsor
If you indeed have a 383 in front of a stock 4l60e You need to give us a call
__________________
Call 888-744-6542
