Installed 2800 Yank Yesterday
Old Dec 24, 2006 | 01:30 PM
White_Ls1's Avatar
Default Installed 2800 Yank Yesterday
I was quite a task, took the better part of a day and a half by myself, I replaced the front and rear trans seals while I was at it and so far no leaks or anything falling off so I feel good about it. I have put about 160miles on it so far half street and half highway, have not done any WOT pulls on it yet but I might later today It does make a little noise at about 2500 rpm and a load, say about 20-30% throttle and goes away right after letting off the gas or after a it gets above a certain rpm. The noise is hard to describe, kinda like a "tin" sound, similar to a heat shield or something but I have checked them they are secure. Do any of your after marker converters make any noise? Happy Holidays -Dave.
Old Dec 24, 2006 | 04:15 PM
AK's WS6's Avatar
Chances are it's not the converter, when you are listening for something to be wrong you'll usually find something little no matter what. I'll be the first to say it.....your going to wish you went bigger!!
Old Dec 24, 2006 | 04:22 PM
35ss's Avatar
whats the stock converter rated at
Old Dec 24, 2006 | 04:23 PM
GMRACER13's Avatar
True story!
Old Dec 24, 2006 | 04:36 PM
TonyGXP's Avatar
Not if he doesn't drive one that has a higher stall in it .. go back and Double check all the bolts, including the TC's, I like to use Lock tite on EVERYTHING personally... MAKE SURE if all else checks out you don't drive it until you have it checked out by a trans guy.. could also be an internal problem and driving on it could destroy everything..
Old Dec 24, 2006 | 04:44 PM
White_Ls1's Avatar
I made sure to use locktite on the converter bolts. I'm going to go do a visual on it now. Thanks -Dave
FLT's Avatar
FLT
You might have a cracked flexplate or a loose tc bolt. I would get it figured out asap. Vince
Old Dec 24, 2006 | 07:08 PM
White_Ls1's Avatar
OK, pulled off inspection plate and tab, inspected front and back of flexplate, looks good. Unbolted converter, double checked clearance it is about 1/4in, reinstalled and torqued to specs. I found that I left the d/s o2 sensor bracket loose, so I secured it. Reinstalled starter and test drove, same noise it is like a slight rubbing noise I can hear it from about 2500-4500. Stumped.
Old Dec 24, 2006 | 07:28 PM
FLT's Avatar
FLT
I'm saying this is the problem but your flexplate could be cracked around the crankshaft bolts. Make sure that your exhaust isn't rubbing on the driveshaft and that all the crossmember bolts are tight.
Old Dec 24, 2006 | 07:35 PM
White_Ls1's Avatar
Forgot to mention, it is only under load, normal driving is ok, if that makes any diffrence.
Old Dec 24, 2006 | 07:42 PM
FLT's Avatar
FLT
Things could be flexing with the motor. I would suggest going over the install again. It's either something happened on the install or the is a problem with the new tc.
Old Dec 24, 2006 | 07:43 PM
White_Ls1's Avatar
Thanks Vince, back to the drawing board again.
Old Dec 26, 2006 | 01:11 PM
White_Ls1's Avatar
I have come to the conclusion it is a heat shield rattle( kind of relieved). I love the way it feels by the way, good mod in my opinion.
Old Mar 22, 2007 | 07:00 PM
Tainted's Avatar
I truely hate bringing threads abck from the dead but I got a question to the original poster: how is it around town as far as normal driving?
Old Mar 23, 2007 | 02:48 PM
dpw41285's Avatar
tainted you know you will go bigger. My ss3800 is at yank right now!!!!
Old Mar 23, 2007 | 04:38 PM
Tainted's Avatar
no...I dont want to go bigger im terribly sorry but thats not happening. if yall wanna buy the car from me and put that big of a stall go for it, but until then I'm not getting over a 3k
Old Mar 23, 2007 | 05:10 PM
HossZ28's Avatar
When I went to the track a couple of months ago I saw some guy with a tolue trans am. I asked him what he had done. The first thing he told me was that he had a 3000 stall and he wish he had gone bigger. He said he planned on going up to a 3500 pretty soon.
Tainted, the only negative you have is that you have a high mileage car. I dont know how trannies react to huge stalls with high miles. That is the only reason to why I could agree with your choice of 2800
I personally dont have a stall, but everytime I see threads about stalls, most people wish they had gone bigger, or have already gone bigger. I will learn from their mistakes and go at least a 3600 stall. You have to remeber it is not only stall size but str also.
Old Mar 24, 2007 | 07:43 AM
Ragtop 99's Avatar
2800 in an LT1 is pretty safe choice.
Old Mar 24, 2007 | 10:36 AM
gyrene2003's Avatar
yeah, i was gonna go for like a 3200 or a 3400 but have decided on the yankss3600. i dont go to the track alot but i want the most bang for the buck since i dont get a chance to do big mods that often cause of the fam!
Old Mar 24, 2007 | 11:49 AM
HossZ28's Avatar
From what I read, you will love that ss3600.
By Brett Foote | 2026-06-04 05:00:17
