4l60e shifting problem
Old Dec 29, 2006 | 12:00 AM
thebulgd's Avatar
Default 4l60e shifting problem
When at WOT the trans wont shift into 3rd unless I let off/press the gas peddle, sometimes I have to peddle it a few times for it to shift. It wont manually shift into third if I up shift either. The trans shifts fine at all others times except WOT, nice firm shifts and when I peddle it to get it to shift it hits 3rd gear hard. The car was recently tuned, stock stall, 3.73 gears, 275/40/17 tires. Please help!!
I will continue searching the forum looking for some kind of direction to go. Guess the first place I go is the tuners tomorrow AM.
Old Dec 29, 2006 | 12:06 AM
performabuilt's Avatar
LS1Tech Sponsor
tuning does sound like the best move
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 29, 2006 | 12:14 AM
thebulgd's Avatar
thanks for the quick reply.
Could you give me any idea what he could have mis-programmed to cause thiscondition?
Old Dec 29, 2006 | 12:29 AM
02 BLK WS6's Avatar
Possibly a tuning fix, but I doubt it. Tranny is more than likely going south... Start saving, it could last 20k miles of normal driving or could break the next time you mash the gas....
Old Dec 29, 2006 | 06:48 AM
FLT's Avatar
FLT
I would have to agree with blkws6 that it is probably more of an inturnal problem like the 3-4 clutch pack. If this started right after the tune you might get lucky. Vince
Old Dec 29, 2006 | 08:04 AM
LS1Tech Sponsor
It may be the 3-4 pack but I usually try and give the less expensive things to check on first and with the recent tune its defiantly worth a look first
__________________
Call 888-744-6542
Old Dec 29, 2006 | 04:39 PM
thebulgd's Avatar
Seems it was the tune. I only did one run on it but it shifted nicely, where it wouldn't shift without problems before.
I was considering a shift kit but the mech said either tune or kit but not both. He mentioned that tuning was about as good as a kit, is this true or no? Also willa 3800 stall rush the demise of my tranny?
Old Jan 8, 2007 | 10:51 AM
Black02Bird's Avatar
mine doing pretty much the same thing... define "tune" sorry im new to this
Old Jan 8, 2007 | 12:24 PM
LS1Tech Sponsor
Good to hear is always pays to look at the easy stuff first
__________________
Call 888-744-6542
