feed/return
Old Jan 10, 2007 | 12:50 AM
udlose98's Avatar
Default feed/return
on the 4l60E which one is the top and which is the bottom?
Old Jan 10, 2007 | 01:03 AM
The Sad's Avatar
Find out which line has the rubber hose crimped on, and which just has the hose clamp. The crimped one is the high pressure line from the tranny.
Old Jan 10, 2007 | 01:15 AM
udlose98's Avatar
crimped one is the return? and does the return go into the top or bottom of rad?
Old Jan 10, 2007 | 01:27 AM
Hell'sChariot's Avatar
No the crimped one is from the trans to the radiator. The NON crimped would be the return line.
Old Jan 10, 2007 | 01:35 AM
udlose98's Avatar
return goes in the top or bottom?
Old Jan 10, 2007 | 07:51 AM
FLT's Avatar
FLT
One the transmission the bottom line/fitting is pressure and the top is return.
Old Jan 10, 2007 | 10:51 AM
12secSS's Avatar
And on the cooler, it is backwards (bottom = inlet, top = return). This is to keep contaminants in the cooler out of the trans.
