Firm 2-3 shift?
but for those with good transmissions, does your 2-3 bite as hard as your 1-2 shift?
Added to this the 2-3 shift is a bit more complicated since the oil supplying the 3-4 clutch is also used to release the band at the same time so with a given about of fluild volume available its used in more places,This is compounded even further during manual shift from 2-3 because the overun clutch is turned on during this shift also which leaves fluid needing to be applied in three different places . BAND RELEASE,OVERUN APPLY AND 3-4 CLUTCH APPLY which is why you tend to hear more stories of the bumping the rev limiter on a manual 2-3 than in the OD position.
However of note when theres no mechanical issue involved and some type of shift improvement (kit etc) has been made from looking at what people are saying I think the hitting of the limiter is more likely a failure to anticipate the shift time or lag from command to actual shift since with the additional applications going on it takes more time for this clutch to apply.I have ready threads in forums where in order to get a 2-3 shift at 6200 rpm the shift timing had to be set as low as 5100 rpm but that did solve there problem.
This problem can be compounded by transmissions with excessive 3-4 clutch clearance and its effect is always increased with any power mods that will let the engine turn up faster.
But overall if your having the 2-3 hits the rev limiter issue and provided the 3-4 clutch is in good shape and the set clearance is not to high most likely its a failure tuning wise to anticipate the lag time between the electrical command for the shift which is instant to the reality of the mechanical actual time it takes to move the 3-4 clutch to the apply position , I would first work to lower the shift RPM and MPH for the 2-3 shift to its lowest setting then if it stops hitting the limiter gradually raise these to get what I was looking for .
If you still hit the rev limiter with this low shift setting i would look for a mechanical issue which could involve work to the 3-4 clutch or increasing feed to the 3-4 clutch further and we have noted many builders do leave the 3-4 clutch clearance to high both initially and by failure to anticipate compression after the set has been applied a few times
When I put the transgo kit in my A4 I also installed a borg warner 3-4 clutch pack with 8 thick frictions and steels set at .045.
That doesn't solve the problem alone you also need to get the feed and release holes in the seperator plate sized for your application. For me it's trial and error, or just stick to what the kit says.
The feed holes need to be right because 2-3 shift feel is a combination of second releasing and third applying, it all needs to work together, this includes the second servo adjustment.
I also shortened the desired shift times and increased line pressure under the 2-3 shift modifier in HPTuners.
I had the transmission out 3 times, and the valve body off about 6 times to get it perfect.
The first time for hole sizes in the seperator plate I took the advice of a sponsor that used to be here and it made it worse. Ruined the seperator plate.
I was just explaining the mechanics of why the 2-3 shift tends to be weaker feeling than the 1-2 shift
This is true, but do you HAVE to blow your own horn constantly? The tech was great and useful, and I do realize you're really only here to sell product... but you know, if you'd leave it at tech comments, I might assume you were too busy building great transmissions to respond constantly to every single trans thread numerous times... which makes me wonder why you have so much time on your hands.
