Trans Shifting Softer
now, it's important to know that last week, i swapped out my stock steel driveshaft for an aluminum race driveshaft. the driveshaft feels about 20 lbs lighter than the stocker. also, the yoke needed to be greased up because it was a tighter fit than the stock yoke, obviously since it didn't have 35,000 miles worth of wear on it. now, would taking 20 lbs off the driveshaft account for the softer shift? should i have anything to worry about? again, everything is shifting fine, no slipping or driveability problems. the shift is just a lot weaker and a lot less satisfying. it feels like a damn 4 cylinder shifting. no ***** at all. this problem didn't start until i replaced my driveshaft with the lighter one. does this make any sense?
Howeever, I beleive the stock steel driveshaft is only 11-12lbs heavier than the stock aluminum shaft. So if your new shaft is actually 20lbs lighter, that's a much bigger differeance than what it would be from the stock steel to the stock aluminum.
i went to napa today and put a new napa gold paper filter in. trans is still shifting soft. however, when i'm making a wide LEFT turn and the trans shifts 1-2 during the turn, i still get that nice kick in the pants i always had before. this leads me to believe that it is the new light driveshaft that is causing the weak shifts. maybe the yoke is still very tight. we had a tough time getting it to bolt up since it was so new, and we had to grease it up to get it in there. it just feels like the trans isn't hitting the rear as hard. maybe this is a good thing? time will tell. i'm just confused as to why the 2-3 shift feels the same or better than the 1-2 shift.
anymore ideas, anyone? has anyone else replaced their steel driveshaft with a lighter driveshaft and had their shifts soften?
Have you checked your trans. fluid level...?
Did you clean your MAF sensor...?
Joe
did i clean the MAF sensor? no, but i did when i put my FTRA in a few months ago.
and it may all be for nothing
plus, i have no time for the car to sit at a shop again. argh! Last edited by Jeff 97 Formula; Jan 15, 2007 at 07:07 PM.
it's important to tell you the tranny was not flushed. it was a simple fluid/filter change. i'd be wary about flushing a trans.
i CAN tell you that when i originally changed the tranny fluid, the fluid level was a bit high. it was overfilled a tad, maybe an inch over the line. it shifted easier after the fluid swap as i didn't fill it as high. still though, it was a pretty decent shift.
but like i said, i'll check wednesady. i'd check tomorrow, but i will be in philly until 11pm and it'll be dark out by the time i'm free
One thing you mentioned is that you had your exhaust retorqued. If it was hitting the floorpan the PCM can and will see this as a misfire. This will affect the EPC output.
Was your battery disconnected at any point recently? If so your PCM is probably in a relearning cycle. But really though, there is no one in your area that can understand and diagnose this condition? Really?
Oh one more thing... don't make the mistake of taking it through a violent WOT until you understand the problem better. There is always a cause and effect when any vehicle becomes symptomatic... do yourself a favor and don't contribute to the severity of the effect.
g
g
i will also check the fluid level tomorrow with the trans warmed up in park.
