Converter Problems?
Old Jan 22, 2007 | 09:45 AM
95TXTA's Avatar
Default Converter Problems?
What are some of the symptoms people here have had when their stall started to give out?
I'm not having consistent problems yet, but I want to get a better idea of what to look for. It seems when i'm coming off the highway and everything is warmed up well and it is downshifting, i'm getting symptoms as if something were slipping.
Twice now I have come of the highway and got on to the access road and coasted to a lower speed, to about 2 gear, and hit the gas and saw the speedo just drop to almost zero and start to fluctuate up and down even though I still hear the engine reving.
1st time I came to a complete stop and gave it gas and it finally caught and went fine. Second time I kept my foot on the gas and it finally caught and kept going.
I don't think it's my clutches slipping. When I am doing short distances in just regular stop and go traffic, or after a cold start all gears shift firmly and consistently. It just seems to happen after I have done some distance (hwy driving) at higher speeds. I also am wondering if maybe a fluid issue?
One other thing I noticed in case this helps, it seems to take a lot longer for it to shift into 4th. Car has 3.42 gears so the speedo is off and I know I need my shift points set but it seems to really rev high before finally dropping into that gear only.
Any ideas appreciated.
Old Jan 22, 2007 | 01:56 PM
95TXTA's Avatar
bump.............anyone?
Old Jan 22, 2007 | 02:25 PM
performabuilt's Avatar
LS1Tech Sponsor
Well first I would check the fuild level since that is at first look kind of what it sounds like
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 22, 2007 | 10:09 PM
Greaseymec's Avatar
It might be a VSS problem if you are still moving and the speedo drops to nothing. Kinda thinking maybe its causing a limp mode. Take a look at the VSS connector to make sure its clean and connected. Keep us updated.
Mec
