big stall guys please chime in..
it seems pretty sluggish when cruising..until I gun it.. then flashes up to 3500-4000 and grabs pretty good. normal right?
dosen't seem to have the seat of the pants feel when getting on it, my last stall was called a test torque, no stall at all... just to hold me until this setup. but seemed much stronger pulling. and spun alot more. 1/2 way thru second. this new stall grabs second, dosen't spin much if any..? normal.
and when shifting when getting on it, rpm's dosent drop below 3,000 rpm's between shifts..Normal right?
sorry for the stupid questions, my last true stall was a cheap tci breakaway 2200 stall. and it was a breakaway allright, came apart and took out my first tranny...
I guess I'll get use to it, just seems really to be sluggish and slipping, shifts good and firm, just sluggish when cruising......
just don't have the seat of the pants feel like the no stall did when pulling... thanks for any help...
But if it's spring or fall temps outside then I easily spin into second. But for the most part I have to say normal on this one.
I have a Yank Super Stock 3800. It has a 2.55 STR. My shift extension is right around 5300-5400. It keeps the engine in the heart of the powerband. With the 2.55 STR, the car will spin the tires when down-shifting into second sometimes (below 40 MPH).
It sounds like you are okay, and I'm sure with a Fuddle you are.
I did check it when the car was warm,idling. and it was a 1/2 qt. low. would that make it act any diff? I might have overfilled it by 1/4-1/2 qt. is that okay?
it's not leaking any, the tranny shop said to just check it, because it could of had some air pockets in it, after install. but anyway I'll have to play with it, when the weather clears up...thanks for the info...
