Help me troubleshoot
Old Feb 6, 2007 | 09:33 PM
02 BLK WS6's Avatar
Default Help me troubleshoot
Fresh rebuild on 4L60E, installed a vig 3600. Tune is the same as it was before the build with stock converter. The tranny will not go into 1st gear, even with the shifter in 1st. Where should I start in the troubleshooting????
Old Feb 6, 2007 | 09:39 PM
performabuilt's Avatar
LS1Tech Sponsor
ok does it shift out through 2-3-4?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 6, 2007 | 10:00 PM
02 BLK WS6's Avatar
Yes, and the converter locks @ highway speeds 40+ mph.
Old Feb 6, 2007 | 10:13 PM
LS1Tech Sponsor
Sounds like a sticky valve solenoids out because it have to be off to make 3rd and on again to make fourth.
sent PM
__________________
Call 888-744-6542
Old Feb 6, 2007 | 10:48 PM
BubaGumpShrimp's Avatar
remove code po757
Old Feb 7, 2007 | 11:42 AM
02 BLK WS6's Avatar
Originally Posted by BubaGumpShrimp
remove code po757
Didn'tmake a difference
Old Feb 7, 2007 | 12:18 PM
LS1Tech Sponsor
I sent you a link to fluild diagram pages to so you can better understand to trouble shoot I hope it helps
__________________
Call 888-744-6542
