Broke something..
Old Feb 11, 2007 | 07:52 AM
the_merv's Avatar
Default Broke something..
Yesterday me and a friend lined up on a road to mess around. We started from a stop, I launched pretty easy cause I have sticky tires on it, and I wanted to give him a little edge off the line so I can punch it and fly by him. Had it at about 3/4 throttle and then layed into it at about 3500RPM. As soon as I did that, I heard a loud bang, he heard it also cause he was right along side of me, and then it was clanging and bucking back and forth. It felt like the Rear had busted, but it was still moving under it's own power. I got it to a stop, he came over and we looked underneath.
When it's in Drive, the Driveshaft doesn't spin at all, so that factored the Rear out of the problem. Then I got it to limp to my Storage place where I have my other car. It moved, and shifted normally the whole way there. I think it's somewhere in the Tailshaft, any ideas? It's a 4L60E.
Old Feb 11, 2007 | 09:12 AM
performabuilt's Avatar
LS1Tech Sponsor
When you say got it to limp to storage what do you mean ,And do you mean in the od/d or last position before nuetral it wont move?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 11, 2007 | 09:26 AM
the_merv's Avatar
The linkage is fine, it goes through all Gears. When I say it limped, it would catch inside and then it would move, clunking the whole way. If I was on it a little, it would clunk louder, letting it coast it clunked, but not too loud. It sounded like the Driveshaft was hitting something. It would move under it's own power, you could tell when it would catch inside on whatever broke. It shifted through the Gears fine when it was moving, it upshifted and downshifted with no problem. I think it's in the Tailshaft area.
Old Feb 11, 2007 | 09:40 AM
LS1Tech Sponsor
Well would be hard to make a diagnosis but it may be a broken rear planet or I have seem the low sprag support rip through the case lugs also . In anycase with the noise your decribing there will be some serious carnage in there im sure ,
If you need anything from us just give us a call , Sounds like your gonna need something from somone.
__________________
Call 888-744-6542
Old Feb 11, 2007 | 09:46 AM
02 BLK WS6's Avatar
Sounds like the sprag let go and the reverse input drum and sunshell got misaligned causing carnage similar to my tranny. If I am correct, your sunshell is carving the inside of your case.
Old Feb 11, 2007 | 09:56 AM
the_merv's Avatar
When it goes into Reverse, it back-lashes. Someone have a pic of this stuff, I don't know exactly what you guys are talking about, I am an Engine guy..
Old Feb 11, 2007 | 09:59 AM
LS1Tech Sponsor
actually theres a whole thread with pics of it , Ill look for it but i think it was posted by 02 black?
__________________
Call 888-744-6542
Old Feb 11, 2007 | 10:00 AM
the_merv's Avatar
I'll look for it also.. if you get anything, post it up.
Old Feb 11, 2007 | 10:13 AM
LS1Tech Sponsor
here you go and he has a previous one to called carnage
https://ls1tech.com/forums/automatic-transmission/631448-more-carnage.html
__________________
Call 888-744-6542
Old Feb 11, 2007 | 06:54 PM
the_merv's Avatar
I will probably just drop it completely out, get it built, and get a Stall in it..
Old Feb 11, 2007 | 07:04 PM
LS1Tech Sponsor
you also might consider just getting a complete unit from someone like us and just swap it out. You get to keep your old one and shipping is included in our prices plus this weekend you get a free cooler too and 50 dollars off because your and ls1tech member
__________________
Call 888-744-6542
Old Feb 11, 2007 | 07:24 PM
the_merv's Avatar
Or what does it cost to have the old one sent and built?
Old Feb 11, 2007 | 07:30 PM
LS1Tech Sponsor
actually since we pay the shipping to get it to us and all and since the cores are inexpensive anyway the cost for you to send yours would be the same as just buying one out right from us , Our typical cost to buy a core is 100 to 150 dollars , Our cost to ship yours to us is also 100 to 150 dollars , So unless you just want your original casing to use for some reason your better off just to order ours outright and its alot faster to if you ordered today you would probably ship mid week if not sooner, Where is you sent your in there would be no cost savings and you would add the 3-7 days in transit to the order time
__________________
Call 888-744-6542
Old Feb 11, 2007 | 07:43 PM
FLT's Avatar
FLT
If you would like to send to me, I will custom build it for you. FYI We currently have a three week backlog. Give Chuck a call for details. Thank you for your time. Vince
