Paging ALL TH400 Users!!!!
Old Sep 3, 2002 | 01:28 PM
NOS powered LS1's Avatar
Default Paging ALL TH400 Users!!!!
What is EVERYTHING I need to do a 99 A4 to TH400 swap, and where is the best place to buy it all?
Old Sep 3, 2002 | 09:17 PM
TRYMYZ's Avatar
Default Re: Paging ALL TH400 Users!!!!
TTT I want to know also <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 3, 2002 | 09:49 PM
BIGBOS's Avatar
You need to get the CPU reflashed...
New drive shaft
New Torque converter
Cross Member
TH400
Tranny Cooler, Lines, Etc
Flexplate, (probably reuse the one you have)
Those are some of the important things... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 7, 2002 | 05:39 PM
ttt
Old Sep 7, 2002 | 08:14 PM
chevyguy3's Avatar
dipstick tube, speedo sensor, reluctor ring
Old Sep 8, 2002 | 01:30 PM
taqwache's Avatar
i was insterested in this also but i got a T56. i want to know who sells all the parts to do the job.
Old Sep 9, 2002 | 12:20 AM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">You need to get the CPU reflashed...
New drive shaft
Cross Member
TH400
Flexplate, (probably reuse the one you have)</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">A4 to TH400, you can use your stock crossmember. The TH400 is only ~2" longer than the 4l60e. I simply moved my mount pad backwards 2".
You can also use your stock cooler lines
ATI built my convertor using the LS1 bolt pattern, so I used my stock flexplate.
You don't HAVE to get your PCM reflashed. But, you WILL have a ton of codes which you can have deleted with LS1 Edit. Ihave been driving mine for about 1 month with no reflash and I still haven't had the codes removed. No problems.
Tim
You can also use your original shifter IF you go with a forward pattern valve body.
