Converter swap number 12
Old Sep 13, 2002 | 07:17 PM
JNorris's Avatar
Moderator
Default Re: Converter swap number 12
Thanks for the info.
John
Old Sep 14, 2002 | 12:25 AM
Ragtop 99's Avatar
The 4400 is not really much looser than the 4000. I could not tell any difference between my 4200 and 4000. However both will be noticably looser than your vig 3200.
Lee, you putz! <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Shift extension is the difference between input shaft (i.e. engine rpm) and the output shaft (tranny input rpm). When you shift to 2nd at 6000 rpm, your tranny input actually drops to around 3300, but with your high stall allows the engine to hold 5200 rpm. The 5200 is refered to as your shift extension. It allows the engine to stay higher in the rpm band and make more power and provides some torque multiplication until the output shaft starts to really catch up to the input shaft.
Old Sep 14, 2002 | 10:13 AM
sweetTA's Avatar
Where are you shifting at to get it to hold 5500rpm? My ST3500 only holds to around 4500 shifting at 6K
Old Sep 14, 2002 | 05:33 PM
Patrick G's Avatar
LS1 Tech Administrator
I am shifting a 6600 rpms to get 5500 rpm shift extension, but it would still drop back to 5500 even if I shifted at 6200...that's what's so great about this converter. The shift extension makes it killer from a roll.
Patrick
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Sep 15, 2002 | 11:11 AM
alexWS6's Avatar
off topic, but how do you get a 111 LSA cam to idle in an automatic?
Old Sep 16, 2002 | 08:27 AM
Patrick G's Avatar
It's easy to get a 111LSA cam to idle with custom tuning. Mine was done by Thunder Racing. I have 2 pcms. One has the idle at 750 rpms and low eninge timing (my nitrous pcm) and one has idle set at 900 and more engine timing (my daily driving pcm). Idle is nice, even at 750 rpms, but my alternator charges better at 900.
__________________
