major tranny problems, Need help
Old Feb 19, 2007 | 01:28 PM
import slayer's Avatar
Default major tranny problems, Need help
On friday I was cruising on the highway when I hear this noise in my car and all of a sudden there was smoke everywhere. When I pulled over there was tranny fluid all over the ground. Today the shop calls me and tells me that the front pump has been completly torn up. They are saying that it could be the converters fault and right now they are still messing with it. That really does not make any sense to me. My converter has only about 1500 miles on it. What do you think could have caused this, has anyone ever heard of this before and how much do you think this will cost to fix?
Old Feb 19, 2007 | 03:51 PM
to the top....
Old Feb 19, 2007 | 04:01 PM
Yank's Avatar
Have you had any harsh shifting or SES lights or made any adjustment to raise pressure settings as this sounds like high line pressure, this might have cracked the pump drive gear making it come apart
Old Feb 19, 2007 | 05:08 PM
performabuilt's Avatar
LS1Tech Sponsor
I would have to see what actually happened to the pump but unless the converter or flexplate came apart or the bolts came loose and you have allready been driving it 1500 miles I would thing it unlikey that would have killed your pump .As yank mentioned High line is a possibility but you would have noticed and xtreme change in shift quality I would think , If I was you i would goto the shop and ask to see the pump and take a camera and post the pic here you get along with there explaination of what happened .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 19, 2007 | 08:33 PM
The only diffrence in shifting was the 1-2 shift. It was really firm. But when this happend I was crusing at 60mph. that is why it does not make any sense.
Old Feb 19, 2007 | 08:54 PM
LS1Tech Sponsor
Was it alot firmer than it was in the past before this happened.
Try and gets some pic of the inside of the pump if you can tomorrow
__________________
Call 888-744-6542
Old Feb 19, 2007 | 08:58 PM
j99fbody's Avatar
were you running a external trans cooler, could be possible you over heated the trans and burned up the pump
Old Feb 19, 2007 | 09:01 PM
LilSlo1's Avatar
Things always break when you are just cruising.....
Old Feb 20, 2007 | 10:58 PM
LS1Tech Sponsor
True it does seem that way lol
__________________
Call 888-744-6542
Old Feb 22, 2007 | 02:40 PM
my tranny shop is charging $1400 to put in a new pump and repair the outside of the converter. Do you think that I am getting ripped off.
Old Feb 22, 2007 | 03:01 PM
LS1Tech Sponsor
Well its a little on the "ouch" side hopefully they are going to warranty the unit.
__________________
Call 888-744-6542
Old Feb 22, 2007 | 03:14 PM
They did my tranny and it was under warrenty but when they built my tranny I gave them a Yank PT 4400 and they would not warrenty that so when my tranny took a **** they naturally blamed it on the converter and I had to pay. Something is starting to smell like BS to me
Old Feb 22, 2007 | 03:53 PM
LS1Tech Sponsor
sorry to hear that
__________________
Call 888-744-6542
Old Feb 22, 2007 | 03:54 PM
Yank's Avatar
Get the converter back to us!
ASAP as the parts are special and if they cut it open you will lose the warrenty on that also.
Old Feb 22, 2007 | 04:15 PM
they already said that they fixed the converter. It was the outside of the converter that was messed up not the inside.
Old Feb 22, 2007 | 04:18 PM
LS1Tech Sponsor
Thats strange you didnt happen to get any pistures of the damage did you ?
__________________
Call 888-744-6542
Old Feb 22, 2007 | 04:31 PM
i didn't get the chance to because as soon as the tranny went out on me I had the car towed to the shop ( on a friday night ) On monay they shipped out the converter and started working on the tranny. So I never got the chance to take pics. I really wish that I could of.
Old Feb 22, 2007 | 05:53 PM
Yank's Avatar
I do not know of any part other than the crank pilot that you can replace without cutting the converter apart and rewelding it again.
sounds more like they cleaned up the marks on the hub that the pump gear made when it broke
