Lubeguard???
Old Feb 28, 2007 | 04:33 PM
Ls1Envy's Avatar
Default Lubeguard???
The guy building my Tranny told me to buy a Bottle of Lubeguard(10$)
What are you gaining from this stuff and is it worth the money?
Old Feb 28, 2007 | 05:13 PM
performabuilt's Avatar
LS1Tech Sponsor
Its a good product we use there assembly grease, Its best known for preventing converter shudder and helping to avoid sticky valves.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 28, 2007 | 06:12 PM
Ls1Envy's Avatar
Ok cool, just wanted to make sure before i bought some. Do you guys put it in your built trannys?
Old Feb 28, 2007 | 06:17 PM
Montec's Avatar
we use smart blend where i work. Basically the same stuff.
Old Feb 28, 2007 | 09:14 PM
LS1Tech Sponsor
Yes I have used that also seems to be good stuff to
__________________
Call 888-744-6542
Old Mar 2, 2007 | 11:09 PM
WE TODD DID's Avatar
There are a few different versions of lube guard. If you use a high grade atf like mercon v, or a synthetic, you shouldn't need any.
Old Mar 2, 2007 | 11:56 PM
LS1Tech Sponsor
True the high end fluilds allready have the friction modifier properties of lube guard
__________________
Call 888-744-6542
