3rd gear problems
Old Mar 2, 2007 | 10:46 PM
Tmoney's Avatar
Default 3rd gear problems
At WOT 1-2 shift fine but it dosent shift into 3rd on my 2000 ta with a 4le60. Someone told me it might be my transGo shift kit doing this dose any one got some insight
Old Mar 2, 2007 | 10:48 PM
performabuilt's Avatar
LS1Tech Sponsor
Not likley the transgo but most likley the 3-4 clutch set is going
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 2, 2007 | 10:59 PM
WE TODD DID's Avatar
Does it have reverse?
Old Mar 2, 2007 | 11:04 PM
LS1Tech Sponsor
Third/reverse
__________________
Call 888-744-6542
Old Mar 2, 2007 | 11:23 PM
Originally Posted by performabuilt
Third/reverse
I had a brain fart.....I was thinking about the sun shell, but hell thats only gonna effect 2nd and 4th.
Old Mar 2, 2007 | 11:28 PM
LS1Tech Sponsor
I understand it happens to the best of us at least you know what a brain fart is lol
__________________
Call 888-744-6542
Old Mar 3, 2007 | 08:42 AM
FLT's Avatar
FLT
Default Brain Fart
LOL and also reverse with a bad shell. JFWY But never the less it sounds as the 3-4 clutch is going out. Vince
Old Mar 3, 2007 | 08:46 AM
Tmoney's Avatar
Well i have about 20000 on that tranny and it was rebuilt it also surges in 2-3 shifts around 45mph if im not in it and in 3-4 shift around 55mph if im not in it.
Old Mar 3, 2007 | 09:25 AM
LS1Tech Sponsor
Well again if the 1-2 shift feels good then I would have to say there is a 3-4 clutch issue
__________________
Call 888-744-6542
Old Mar 3, 2007 | 12:46 PM
Z28LS1camaroguy's Avatar
im having a very similar problem, during wot I will have it in D and go WOT and when it comes to shift into third it wont really and i have to let off the gas to get it to otherwise it will go into the red and bounce off the rev limiter. im not sure if its the tune b/c it never did this until i got it tuned so maybe the shift points arent set right there.
Old Mar 3, 2007 | 12:59 PM
LS1Tech Sponsor
In your case that is possible though I still think original poster has a 3-4 clutch issue , You also have to anticipate comand to actual shift lag time when setting shift points particularly with the 2-3 shift since theres alot going on during that shift , fluild is being directed to the back side of servo for band release , and in the 3 0r d3 position fluild is also being directed to the overun clutch compounding this add in a little excessive clutch clearance and it can be 200 to I have seen people say as much as 800 rpm between command and actual shift
__________________
Call 888-744-6542
Old Mar 4, 2007 | 02:58 PM
Tmoney's Avatar
could that explain why it gets a hard chatter before it shifts gears
Old Mar 5, 2007 | 09:31 PM
Tmoney's Avatar
ttttt
Old Mar 5, 2007 | 09:32 PM
LS1Tech Sponsor
slipping can sometimes feel like a rough chatter
__________________
Call 888-744-6542
