Problems after Vig 3200 and SLP LT's...HELP!
Old Sep 12, 2002 | 03:20 PM
NOS powered LS1's Avatar
Default Problems after Vig 3200 and SLP LT's...HELP!
I installed a VIG 3200, B&M 16K tranny cooler, SLP LT's w/ORP, and a TNT F1 kit, and now under WOT the tranny shifts slow as Christmans on the 1-2 shift and the 2-3 shift just bounces off the rev limiter. What can be done to make it shift like it used to? HPP3? or just get an FLP Level IV?
Old Sep 12, 2002 | 06:40 PM
12secSS's Avatar
Default Re: Problems after Vig 3200 and SLP LT's...HELP!
First and foremost, check the fluid level. After my Vig3600 install, my fluid level was 1/2 quart low (a weeke later). This can cause undesirable shifting. If that is OK, I haven't the faintest. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 12, 2002 | 07:55 PM
Ragtop 99's Avatar
How are your LTRIMS?
Does this happen with the lever in D3 and D4? Have you given the computer a chance to learn yet - you rev a lot faster now.
Nitrous often requires the use of lower shift points. Are you using a window switch?
Old Sep 12, 2002 | 08:14 PM
Dont know havent ATAPed it ye
Does this happen with the lever in D3 and D4? both
It has had 2 days now and still the same thing
Nitrous often requires the use of lower shift points. Like what? I thought you would shift around 6200 on the gas
Are you using a window switch? Yes, 3K and 5800, but havent sprayed yet, want to get the shifting right 1st.
Old Sep 15, 2002 | 10:07 AM
98TAauto's Avatar
usually everyone hits the 2-3 limiter after a converter swap. You just simply need to lower your shift points on the 2-3 by 1 till you get off the limiter... also bump the limiter up 100 rpms to 6300... no higher though for stock internals
maybe you just need to raise your 1-2 shift up some.. atap it asap.. that will help you alot find out whats wrong.
log your shifts on atap for a idea of when its shifting
did you check the fuild after you have driven around for like 15mins?? get it good and hot before you check the fuild.... low tranny fuild could cause those issues also!
Old Sep 16, 2002 | 12:45 AM
Slow Z28's Avatar
unless i am blind, and i have been known to miss stuff, but i don't see a shift kit in the list. when you add a torque converter, it makes the shifts pretty sloppy, and that's probably the "slow" feeling you are experiencing. maybe the addition of one would help quicken/firm those shifts up.
Chris
