New Tranny Install
Old Mar 17, 2007 | 06:29 PM
rbrcka's Avatar
Default New Tranny Install
I'm starting the process of removing my old tranny this weekend so I can install my new PerformaBuilt Pro Race and new verter. Do you guys normally add some tranny fluid in the torque converter itself prior to installing it?
Old Mar 17, 2007 | 06:33 PM
performabuilt's Avatar
LS1Tech Sponsor
It fine to do that . I ussually do a little ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 17, 2007 | 07:49 PM
FLT's Avatar
FLT
It's a good idea to pour a 1/2-1 quart into any tc using a lockup clutch. This allows the tcc to be presoaked along with the other internal components.
Old Mar 17, 2007 | 11:43 PM
LS1Tech Sponsor
keep me posted on how it does please
__________________
Call 888-744-6542
Old Mar 18, 2007 | 08:00 PM
rbrcka's Avatar
Will do. I have the old tranny out and I'm just getting things ready to go so tomorrow after work I can put the new one in. What is the best way to flush the stock tranny cooler?
Old Mar 18, 2007 | 08:05 PM
LS1Tech Sponsor
did you not get the flush we sent in the box with the trans
__________________
Call 888-744-6542
Old Mar 18, 2007 | 09:53 PM
rbrcka's Avatar
I went back out and dug through the box to make sure it wasn't covered down in the peanut packing foam, but there wasn't one.
bluecajun5.3's Avatar
11 Second Truck Club
same here.
Old Mar 18, 2007 | 09:56 PM
LS1Tech Sponsor
Go to a trans shop or supplier and pick one up ill credit your card for 25 dollars
__________________
Call 888-744-6542
Old Mar 18, 2007 | 10:39 PM
LS1Tech Sponsor
Attention all Performabuilt customers who have not installed there transmission and have received it in the past 4 weeks.
It has come to our attention that one of the torque wrenches we are using is wrong and when tightened to spec overtightens the bolts to and exstreme level , This wrench was not used on all units so if your trans has been installed and is working fine there is no reason to worry , However if you have not installed your trans we ask that you remove the pan break loose all the valve body bolts at once Then retorque to 8-14 Nm or 7 ft lbs , This is a precautionary measure.These bolts being to tight may cause undesirable operation wrong gears missing gears ect. Again if you have installed you trans and it is working fine do not be concerned, As all units are not affected.
Thank You
PerformaBuilt
__________________
Call 888-744-6542
Old Mar 19, 2007 | 12:16 PM
rbrcka's Avatar
I checked and I actually purchased mine back on 12/23 and rec'd it between xmas and new years. Should I still check or should I be ok? I just ask because I don't have a torque wrench that goes down as far as I would need. So I would have to go shopping for one before I could install it tonight otherwise.
Old Mar 19, 2007 | 12:49 PM
LS1Tech Sponsor
that far back I would not be concerned , You are fine thanks
__________________
Call 888-744-6542
Old Mar 19, 2007 | 11:19 PM
rbrcka's Avatar
I picked up some Kooler Kleen and the stuff that shot out the first 2 or 3 seconds of the flush was brutal looking. Then it cleaned up and ran clear for the rest of the can. Got the tranny installed without too much grief so I'm pretty happy. I still have a couple easy nights of finishing everything up, but I'm on the downhill now!
Old Mar 19, 2007 | 11:22 PM
LS1Tech Sponsor
cool i will do that credit tomorrow for the flush , And let me know when you have it all going
__________________
Call 888-744-6542
Old Mar 21, 2007 | 10:06 AM
rbrcka's Avatar
I got just about everything done now and tonight I'm going to start adding fluids. How many quarts is a good starting point that I can just put in before starting the check/fill process? (I put a 1/2 qt in the torque converter to presoak it)
Old Mar 21, 2007 | 12:27 PM
ohsofast's Avatar
If I remember correctly I bought 8 and used 6 1/2
Old Mar 21, 2007 | 01:04 PM
LS1Tech Sponsor
With rear wheels raised , put in six quarts of fluild , with car in neutral start engine and add till full , With wheels still raised run car through gears several times , Turn off car check for leaks then lower car , Start car in park and check fuild top if needed, If just a little over thats ok , Drive car around approx 20 miles starting and stopping normal driving. Recheck for leaks , Next day start car and warm to operating temperature , Recheck fluild , Top if needed, Your ready to go.
__________________
Call 888-744-6542
Old Mar 22, 2007 | 07:49 AM
rbrcka's Avatar
I noticed when I took the tranny pan off my old transmission that the filter was just sitting loose in it. There is supposed to be a retaining clip holding it in isn't there?
Old Mar 22, 2007 | 10:46 AM
LS1Tech Sponsor
Actually no its held in place by the seal in the pump and the fact it rest on the bottom of the pan , Of note thats why its very important for those who change from a shallow pan to a deep pan that you change to the filter with a longer neck also . I have run into a few instances where persons have changed out there pan for a deep one and then a few days later lost all gears , Only to determine that there filter had fallen out of the pump ,
__________________
Call 888-744-6542
Old Mar 22, 2007 | 12:06 PM
rbrcka's Avatar
Very good information to know!
