MAX shift Transmission Fluid(TCI)?
Old Mar 21, 2007 | 04:14 PM
J'sRedWS6's Avatar
Default MAX shift Transmission Fluid(TCI)?
Anybody heard or know anything about this fluid?Says you can run up to 30Degrees cooler with it over other fluids.Its $71 for 3 gallons.
OFF TCI website
Racing Transmission Fluid (RTF) has been tested and proven to run up to 30° F cooler, even during extreme-heat racing sessions and repeated usage. RTF is uniquely formulated using a new oil-soluble molybdenum additive that greatly reduces internal friction and heat, yet does not affect clutch and band lock-up. It is made using base oils with extremely high viscosity index and the fluid contains a special defoamer agent that reduces fluid foaming even at 10,000 rpm. In addition, RTF contains extreme pressure additives to help control gear fatigue and fracture, actually forming a fluid cushion from metal-to-metal contact.
RTF’s unique color is a result of the dyes found in other fluids being eliminated.
Old Mar 21, 2007 | 08:04 PM
TJ's Avatar
TJ
maybe 30 degrees in the absolute worst conditions.
id say a good 5-8 dregress on averge. i use the PTC fluid(which im sure is the TCI with a different label)
and the fluid doesnt seem to foam/airate as bad when you really really beat the holy hell out of it at the track.
