Converter install
Old Sep 22, 2002 | 02:10 PM
MightyWhiteZ's Avatar
Default Converter install
is there a sure fire way to make sure that the pump is engaged correctly in the tranny? i know of the three click method but any other ways?
Old Sep 22, 2002 | 03:22 PM
dand35th's Avatar
Default Re: Converter install
This is what I do...look at the tranny and find where the notch is then spin it so it is up and down...now place the TC on with the notch up and down..It will go right in.. To be sure just look to see if the mount tabs are in past the tranny mount flange. It is about 3/4 inch from the face of the tranny..
Old Sep 23, 2002 | 09:26 AM
Kristi's Avatar
Yeah, we learned that hard way the damage that can be caused by only making 2 of the 3 clicks <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Sep 23, 2002 | 10:37 AM
Kevin Winstead's Avatar
Measure from the mounting face of the transmission to mounting pads/ring of the converter. It should be 1". There is some tolerance on this, but not much.
Good Luck!
Kevin
