noise in my tranny help!!!! please
Old 03-30-2007, 11:16 AM
ncd1966's Avatar
Default noise in my tranny help!!!! please
ok the other day I'm leaving work in my TA no big deal.
Well I start hearing a rattling noise like were the flywheel and convertor is. Sounded like something let loose and started flying around. So I went get the truck and trailer and bought it back home. Well when I backed it off the trailer the noise quit but now the motor has a vibration when rev it around 2000 rpms and up. So I decided to go drive the car and see whats going on last night.
Well the transmission shifted fine the Stall feels normal but i still have the vibration when in park or neutral.
It think I might of crack my flywheel or maybe a bolt came loose on the convetor I don't know. And I just got my car out of the Tranny shop like a month ago. With a new stall and new clutchs and a new drum.
I going to pull out the starter tomorrow and see if anything is broken
Anyone else had this happen
Old 03-30-2007, 11:24 AM
GregWS6&z28's Avatar
sounds like a converter bolt came loose. that could have been the noise you heard and why there's a shake to it now.
Old 03-30-2007, 12:15 PM
Doc
Doc's Avatar
What type of exhaust do you have? X, Y pipe? Are you sure it is not a y pipe banging?
Old 03-30-2007, 12:19 PM
ncd1966's Avatar
i have a y pipe and it doesn't bang at all...
I think its defently the convertor bolt that would explain the vibration at 2000
