Performabuilt 9.5 inch converters
Originally Posted by 24v
I put the tranny and converter in Saturday, and tuned it Sunday, so no time yet. I will be running the 1/8th mile this weekend, however, I have added a few other mods since my last time at the track, so I am not sure how accurate the results will be. I am shooting for high 6's in my 3900lb beast.
Do you happen to have a dyno from when you were running your old stall? Did your power levels stay about the same after the swap?
I'm planning on spraying the converter locked, atleast for 1 pull. probably around 550hp range next year.
Originally Posted by waterbug1999
I wish the people above that have these verters would post up what their STR is...
LS1Tech Sponsor
I only made 1 locked pass, and there were no signs of slippage. The unlocked numbers were 492/445. Do you guys offer a converter that is ok to lockup at WOT? I always dyno the last pass or two with the converter locked as that is what all of my previous comparison info is based on. Hell, I made about a dozen locked passes in a row on my fuddle converter with no slippage.
Lets hope the single clutch converter will hold up.
Generally though for people who want to lock on a regular basis not just on the DYNO at WOT its generally a good idea to use a multi disc clutch , I dont even think yank suggest locking at WOT with there converter either from post I have read. Im not saying you cant do it or that it wont do it but it could possibly shorten the lockup clutch life, You have to remember your asking a really small comparativly clutch to do the same thing as the ones in a manual car have to do and you know how much surface area and presure they have and they still die too
__________________
Although I can give you a locked/unlocked comparison.
Fuddle
440/425 unlocked
480/460 locked
Performabuilt
492/445 unlocked
511/500 locked
Different power levels but you can get an idea of efficiency maybe?
LS1Tech Sponsor
Actually we started selling and making our own to reduce risk since while we have had a couple other peoples converter take out or at least clog up our trans with crap which we still took care of our customer. We have yet to have one of our converters to fail , Not saying it wont happen because anything mechanical can fail but so far at least its been a good move for us.
__________________
...Although I can give you a locked/unlocked comparison.
Performabuilt
492/445 unlocked
511/500 locked
Performabuilt
492/445 unlocked
511/500 locked
Originally Posted by performabuilt
Yes I would like some pics of that since its the first I have heard of it,
Here ya go! Sorry for the huge blurry pic, but I think you can get the idea. It shows the converter foot resting on a weld. This pic was taken before I broke out the die grinder and took some metal off of the back of the foot. Since the welds don't go all of the way around the flex plate, I also considered reindexing the converter and drilling three new holes. I didn't have a good drill bit, so I opted for the grinder instead. Like I said in the earler post two out of three of the feet looked like this, and the third one barely cleared.
Originally Posted by Tainted
humm maybe that was jsut a problem from the factory that the welds were so thick
Considering their purpose the welds don't look overly bulky, in fact they are kind of skimpy. That's why I chose to grind on the converter instead of the welds.
The bolt hole on the right is the one that lines up with the hole in the flexplate. The factory converter foot centered up on that hole, wich kept it away from the welds. To me the problem seems to be the extra metal required for the bolt hole in the new converter, that is offset to the left and a little closer to the outside.
#35
LS1Tech Sponsor
drivabilty is not that different between a 3000 and 3500 with our stalls , But while 3k would probably be enough 3500 would be more fun , but I will say this again since many dont know you can get any stall in our 9.5 inch from 2600 to 5500 pricing structure works like this 2600 to 3000 priced as 3000 3100 to 3500 priced as a 3500 etc etc .
__________________
#39
Guys, I would go up 2 sizes on the stall from what you think you want. I am wishing I had bought a 4000 instead of the 3500. I had a fuddle 3200 in the car, and it flashed perfect at the drag strip. I feel the new 3500 is a little too tight for what I was looking for. However, other than that, I love the tranny I got from performabuilt. Great deal, and a great shifting tranny.
#40
