Performabuilt 9.5 inch converters
Performabuilt if you read this do you mind looking up the STR of my converter? I think the 4000 stall will end up being one of the more popular units you sell to many H/C LS1's.
I've driven a few different converters, The TCI rates there's at 2.5, but honestly it feels a little lower than that, like 2.4ish barely.
I am almost 100% sure that there is no way the car is hooking with Nitto's at my power levels or any other type of DR. At a minimum a 16" w/ ET streets.
Like Performabuilt said it seems the converter will stall to the rpm it's built for. For example even though it's tighter when I'm on an incline and ther car is in drive at a stop I'll roll back, the TCI would almost always hold, Yet the TCI was looser once you got that strattor spinning. I do have a little more shift extension as well so I know the converter behaves bigger. I'll see at the track, I know if I loose some MPH and can hook similar to before that the STR is very high, however, my seat of the pants feeling tells me the efficiency is right up there even with the big STR, plus 24V's Dyno #'s prove a much tighter tolerance at lockup.
The problem with brake stall test is that the brakes will let loose well before actual stall speed is reached , You have to bear in mind that when you get close to stall your also geting close to 1 to 1 on the converter and your asking a couple small pad or shoes to hold several 100 ft lbs of torque which is not going to happen ,
Then theres WOT launch method , Problem with this is two fold wheel spin and the fact the car starts moving which again will make the stall or called flash stall appear much lower if the car can hook up that it is or if the car spins then the whole measurement is completely out the door,
The most accurate method short of a trans brake I have found is to put the trans in limp mode 3rd gear and take off WOT this still isnt very acurate but seems to be the best by far, However the 3-4 clutch set even with the best possible frictions etc and At max line as it would be in limp mode potentially could be damaged during this test because they were not intended nor are the capable of holding that level or torque for any exstended period of time.
Now if your are lucky enough to have the ability to start in second gear you could launch in second and hopefully avoid wheel spin , But it still would likley be off by several hundred RPM also But could give you a better idea.
Im sorry none of these are really good answers, Stall speed is a very complicated issue , There are so many variables for instance if your peak torque is reached at lets say 3500 rpm and your stall is a 3500 your stall speed will be very different feeling than lets same the same set up on a car not reaching its peak till 4000 rpm , Turbos/Nos etc again change the effect completly again.
The stall of our converters are mathmatically calculated based on formulas that take in such Information as rear ratio, weight of vehical,estimated or actual if a dyno sheet is available HP an Torque curves and Engine displacement using formulas provided by sonnax who is our source of the parts used to build our converters.
I hope this information helps some though its probably not the simple answer you were looking for.
Frank at PerformaBuilt
