Round trans cooler?
Old Mar 30, 2007 | 07:35 PM
spyterus's Avatar
Default Round trans cooler?
Does anyone know anything about these trans coolers that are 12"-18" long, kind of round, and have fins surrounding them? They come in different colors. Are these any good or are they pure junk? I've never seen them before till today. Just curious.
Old Mar 30, 2007 | 09:05 PM
WE TODD DID's Avatar
Trans coolers are all about the same. Basically its a cooler line wound up with fins on it to dissipate heat.
Old Mar 30, 2007 | 10:29 PM
performabuilt's Avatar
LS1Tech Sponsor
Shape should make no difference , I have seen those they are interesting looking , All coolers basically work the same reguarless of shape but I have found the flat tube type like we are giving away this weekend with trans are more efficent from measureing temp in and out by about 20 percent over the round tube versions
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 30, 2007 | 11:20 PM
DeltaT's Avatar
Are you talking about the brazed plate style cooler? Stacked plates with a reservoir on each side?
Jim
Old Mar 30, 2007 | 11:24 PM
LS1Tech Sponsor
no the tubes are flat instead of round gives a greater cooling area cooling only happens where the fins contact the tubes round or flat
__________________
Call 888-744-6542
Old Mar 31, 2007 | 12:27 AM
kill_machine85's Avatar
They should perform about the same
Old Mar 31, 2007 | 12:31 AM
LS1Tech Sponsor
Actually the round tube coolers have less contact area with the fins and must be larger physically to do the same job.
__________________
Call 888-744-6542
Old Mar 31, 2007 | 02:50 PM
spyterus's Avatar
I see these coolers on ebay most the time. They look like a gimmick rather than something functional. Is anyone using one of these for their tranny?
Old Mar 31, 2007 | 02:52 PM
LS1Tech Sponsor
I kinda figured the gimik thing too and it would seem there might be some mounting impracticality too
__________________
Call 888-744-6542
