3-4 Shift Flare?
Old Apr 5, 2007 | 11:15 PM
RevGTO's Avatar
Pontiacerator
Default 3-4 Shift Flare?
My buddy just got a Transgo shift kit installed. 1-2 and 2-3 shifts are normal, but 3-4 goes like grab-slip-grab-hold. Any ideas as to what could be causing this?
Old Apr 6, 2007 | 05:04 PM
RevGTO's Avatar
Pontiacerator
Bump - anyone?
Old Apr 6, 2007 | 05:55 PM
performabuilt's Avatar
LS1Tech Sponsor
could it be the converter coming on the transgo kit does make the converter lockup much more noticable
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 6, 2007 | 10:14 PM
RevGTO's Avatar
Pontiacerator
No - I know what you're talking about and that's not it. It's like the band doesn't hold at first - slips and then finally engages. The installer thinks that the 4th gear accumulator spring may be weak. I was thinking maybe something was done incorrectly to the 4th gear servo??
Old Apr 6, 2007 | 10:31 PM
LS1Tech Sponsor
well actually if the 4th gea spring was installed as the transgo kit shows it shouldnt matter weak or not its upside down and allready full of fuild so it effectivley not and accumulator any more . There could be excesive clearance for the fourth servo .Is it the stock servo ?
__________________
Call 888-744-6542
Old Apr 7, 2007 | 02:18 PM
RevGTO's Avatar
Pontiacerator
Yes, stock servo. I don't have a set of instructions in front of me, but I know there are a couple of shims or something in there that are changed out.
Old Apr 7, 2007 | 09:40 PM
L-EATER's Avatar
11 Second Truck Club
3-4 feed hole is too big. Get a new separator plate and drill it to the next to the biggest size recommended in the kit instead of the biggest. 3-4 flair is almost always caused by this. Hope this helps.....
Old Apr 8, 2007 | 11:49 PM
RevGTO's Avatar
Pontiacerator
Well, we did have it drilled out according to the Pro-Built specs, which calls for extra big feed holes. This set-up worked great on my converter - but maybe not for his.
Old Apr 8, 2007 | 11:56 PM
RevGTO's Avatar
Pontiacerator
