Another trans dead
I haven't pulled the pan yet either. But, the fluid smells ok.
Could it be a solenoid? Or, would i still have 4th?
I got a replacement and everything seemed good for a couple hundred miles until I lost compression in the engine do to cracked piston ring lands. (the guy who had it before me was apparently hammering it hard with bad tunes) I had it down for close to two months freshening up my forged bottom end. Then a little over 500 miles into my engine break in (very easy driving) I just all of a sudden lost 3-4 on the replacement tranny with no signs leading up to it at all. I actually checked the shifter location like three times to make sure I wasn't in neutral, because I couldn't believe it.
So now I'm to the point where I'm scared to even drive the car for fear of something going out. I have actually removed the procharger and just put on a cold air intake and will most likely sell the car soon. Seems like this car wasn't meant to be.
Seriously, if its not your daily driver and you just want to drive it and have fun put a TH400 in it and be done.
Sadly it is my DD. Or at least that was the plan. Otherwise that would be a great swap.
I still haven't had a chance to mess with the truck yet. Maybe after work today.
Anyway Command at speed 45mph 1st good, 2nd good, 3rd -No change, Feels like second, 4th feels like it falls into neutral.
From a Stop if I command 3rd it stays in second. If I command 4th It goes back to 1st.
Eric
OK, I'll throw in my old set of solenoids out of my original trans and see if the make a difference. Thanks for all the help!
Does it sound like a solenoid problem? I guess I'll know if the old ones work.
