700R4 internals into a 4L60e?
Old 04-11-2007, 12:56 PM
Camnlt1's Avatar
Default 700R4 internals into a 4L60e?
Right now I have a pretty well built up 93ish 700R4 and I'd like to start running a 4L60e for various reasons. I have the electronic end of it handled but my question is will all the internals of the 700R4 swap over to the 60E? I know the valvebody wont obviously but if anyone knows anything else about it, I would very much appreicate it! Thanks.
Old 04-11-2007, 03:33 PM
8a8mfh's Avatar
It will all bolt into a non LS1 4L60E. Everything except the pump and input will bolt into an LS1 4L60E.
And as you know this does not include the valvebody.
Old 04-11-2007, 05:13 PM
Camnlt1's Avatar
I'm looking to do this to an LT1 60e so the Ls1 parts arent an issue. Other than that am I good to go?
Old 04-12-2007, 01:28 AM
8a8mfh's Avatar
As far as I know.
you might look at the pump to be sure it matches but even if it doesn't you can use the internals.
I know the whole gear train will work.
Quick Reply: 700R4 internals into a 4L60e?
