Mcleod Master Cylinder and drill mod install??
Old Sep 29, 2002 | 11:25 AM
Jimmy00Z28's Avatar
Default Mcleod Master Cylinder and drill mod install??
I wanted to get everybody's suggestion on this, I have a 00' Z28 m6, My clutch will stick halfway down and wont come up unless I bring it up with my foot, it sticks when I try to go to 3rd, but on the street when I get on it in second, shift to third and then try to fourth it will do the same thing in fourth, it wont go.?/? Somebody please tell me if I need a new master cylinder or whatever, What do I need to do about this? HELP!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> TIA!
Old Sep 30, 2002 | 07:37 PM
Navy David SS's Avatar
Default Re: Mcleod Master Cylinder and drill mod install??
If your clutch is sticking to the floor you have more issues that the master.
# miles on clutch?
Still original?
Do you race it?
Mcleod's new adjustable master and the drill out mod works wonders for me. I did up grade the entire clutch system with their kevlar set up.
Personally if you have the miles on your present clutch, do with a better set-up. Even the Z06 clutch with Mcleod's master, new slave and the drill out mod will be great for a 'daily' driver.
David
Old Sep 30, 2002 | 08:57 PM
Jimmy00Z28's Avatar
I currently have almost 47k on my clutch, still stock, entire car is stock actually. What all would I need to fix this problem? Is the Z06 clutch a pretty good clutch(i would guess so seeing it is coming from a Z06?) A master cylinder and a slave cylinder? How much would the Z06 clutch be? I want to get this fixed before it gets too late and the whole clutch go out or something? I'm going to the Turkey Rod Run in Nov., Hopefully i'll hav it fixed by then <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
<small>[ September 30, 2002, 08:59 PM: Message edited by: Jimmy00Z28 ]</small>
Old Sep 30, 2002 | 09:22 PM
buschman's Avatar
Since you have an 00 it's most likely your slave cylinder. The part itself is only like $50. Problem is, to get to it you have to yank the tranny. Since you have the tranny out a clutch swap is almost a given.
Mike
Old Sep 30, 2002 | 10:06 PM
Jimmy00Z28's Avatar
GREAT! My friends dad is a mechanic, he also said it might be the slave cylinder, I wanted to make sure before I bought anything I didn't need to,Is the master cylinder need to be replaced to or just the slave? since I have the tranny out a clutch would be a good idea too? What clutch would be a good idea? My car is stock, i'll have the SLP LM quad setup before long, air lid, normal things, maybe Nitrous eventually. Just a daily driver. Any suggestions on clutches? TIA <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
<small>[ September 30, 2002, 11:58 PM: Message edited by: Jimmy00Z28 ]</small>
Old Oct 1, 2002 | 07:30 PM
For a daily driver (and MAYBE a trip to the track once in a while) go with the Z06. Most of the sponsors carry them. My favorite place is www.thunderracing.com . I would say for a daily driver the master should be fine. Do the drill out mod, slave and than the Z06 clutch package. If you can get it replaced by a friend, great.
David
Old Oct 1, 2002 | 09:32 PM
Jimmy00Z28's Avatar
Thanks guys, y'all are awesome!! <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
One day I wish I could be as helpfull to someone as you were to me. I really appreciate it.
My friends dad is a mechanic so he knows what he is doing, of course i'll be there with my friend helping out as much as possible(it's my own car, I have to be there with my baby during surgery'!!)
<small>[ October 01, 2002, 09:50 PM: Message edited by: Jimmy00Z28 ]</small>
Old Oct 1, 2002 | 09:52 PM
Jimmy00Z28's Avatar
Z06 clutch package from LMperformance.com?
Clutch, pressur plate, and flywheel for $490? PLUS the slave cylinder for this clutch for $96? Does this sound right or too much? I have no idea <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ October 01, 2002, 10:24 PM: Message edited by: Jimmy00Z28 ]</small>
Old Oct 2, 2002 | 10:54 PM
xaon's Avatar
OUCH! 490 seems a tad steem for that package.
FWIW. I paid $262.08 for my ZO6 clutch/pressure plate/flywheel package from gmpartsdirect.com (GM List is $436.80, PN 12570281) Can probably figure another 40-50 for shipping and handling on that as well.
I'm not sure what the slave cylinder Part Number is, but i'm sure a search in this section could easily find it. They should also have this as well.
Old Oct 3, 2002 | 03:19 PM
Jimmy00Z28's Avatar
How did you get it so cheap? Thanks for telling me a cheaper place to get the Z06 package!TIA!
Old Oct 3, 2002 | 06:00 PM
xaon's Avatar
I just went to their website and punched in the part number, it came up with a price and I ordered it. (The description only says 'FLYWHEEL', but it's the whole package)
Old Oct 4, 2002 | 12:10 AM
Jimmy00Z28's Avatar
Is there a Z06 slave cylinder that i'll need to get when I get the Z06 Clutch package or could I just order the replacement slave cylinder for the LS1?
Old Oct 4, 2002 | 12:53 AM
Jason99T/A's Avatar
I can shift faster than you.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jimmy00Z28:
<strong>Is there a Z06 slave cylinder that i'll need to get when I get the Z06 Clutch package or could I just order the replacement slave cylinder for the LS1?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Just purchase an F-body slave cylinder with the last three digits being "145". The Z06 slave has the fittings at different angles and will not work.
Old Oct 5, 2002 | 12:12 AM
Jimmy00Z28's Avatar
Thanks!
