Speedometer correction
Old Apr 16, 2007 | 03:47 PM
BCook839's Avatar
Default Speedometer correction
I'm looking into getting some 3.73's for my 96' A4 Z28's rear end but I am concerned with how I am going to correct the speedometer. I know this can be done by reprograming the computer but i dont want to spend 150 bucks on a mail order tune that i only really need for the gears. Is there a gear on the transmision where the speedometer cable gets its reading that i can replace to compensate, or is it a electro-magnetical type sensor that doesnt work with any gears? Is there any way i can do this without the mailorder tune.
Thanks
Old Apr 16, 2007 | 03:56 PM
performabuilt's Avatar
LS1Tech Sponsor
its a reluctor you will have to ajust in programing , Check your area fo someone who does tuning hey check this site for someone in your area who has a programmer
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 17, 2007 | 08:42 AM
BCook839's Avatar
Is the speedometer and odometer the only thing I will need to correct or will i have to adjust anything else in the transmission like any kind of hydraulic line pressure so it shifts correctly?
