4l60e from a truck?
Old Apr 19, 2007 | 12:21 PM
whytryz28's Avatar
Default 4l60e from a truck?
Would a 4l60e from a Truck fit an LS1 camaro, if so what year would i have to look for?
Rob
Old Apr 19, 2007 | 12:36 PM
SuperZ's Avatar
I would think if its a truck that had a 4.8 or 5.3 than its the same trans.The V6s also had a 4l60E but the V6 version.Im not sure if they are weaker or whats different about them
Old Apr 19, 2007 | 02:41 PM
silver-mod-o's Avatar
Custm2500's #1 Fan
the tail housing's different because you guys have holes for your tq arm...
Old Apr 19, 2007 | 03:44 PM
NC98Z's Avatar
The shaft that sticks out the side that the linkage hooks to is different but you can take the one off your camaro tranny and use it.
Old Apr 19, 2007 | 09:33 PM
Arc00TA's Avatar
The output shaft is shorter as well, and has different shaped splines.
