6l80
Old Apr 22, 2007 | 11:47 PM
Mrincredible's Avatar
Default 6l80
Any shops selling modified 6L80 transmissions yet?
Old May 26, 2007 | 11:44 PM
looks like the computer is a problem
Old May 27, 2007 | 12:48 AM
performabuilt's Avatar
LS1Tech Sponsor
Yes a way to control it is the big issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 6, 2007 | 09:21 AM
Mike1234's Avatar
Full MANUAL SHIFT available??
Old Jun 6, 2007 | 09:30 AM
LS1Tech Sponsor
Not yet as far as I am aware
__________________
Call 888-744-6542
Old Jun 6, 2007 | 06:47 PM
Mike1234's Avatar
performabuilt... Any idea when
Old Jun 6, 2007 | 07:40 PM
Predator T/A's Avatar
hell with a six speed i like my 4 speed......
Old Jun 6, 2007 | 07:58 PM
LS1Tech Sponsor
Probabaly not till they are several years old and theres both a conventional and retro market for them.
__________________
Call 888-744-6542
Old Jun 6, 2007 | 09:11 PM
big wally 55's Avatar
You can bet the Younger gang in california will come up with something !!
Old Jun 7, 2007 | 08:42 AM
Mike1234's Avatar
Hmm... should I wait to buy my new tranny??? I've been thinking of going with a 4L80 but if a retrofitted 6L80 is coming soon I might wait a bit.
OPNIONS/GUESSES PLEASE... Will a 6L80 hold up to 700 ft-lb of torque in a 2350 lb car (including fuel/driver)?
Old Jun 7, 2007 | 10:55 AM
camarols1's Avatar
I have seen the production line build up of the 6L80, and it is
a very impressive trans.
Don't plan on a retrofit of this trans into earlier vehicles for a LONG time.
The internal solenoids function in the same manner as the
Allison truck transmissions in that they open to a certain percentage
of flow for a specific time. No simple open/close operation means that there is no simple way to wire a manual "paddle shift" arrangment.
There is an INTERNAL trans computer which must communicate with
the PCM to establish the correct shift at that particular moment.
I asked the builder about a retrofit possibility and it does not seem likely.
I would be surprised to see an aftermarket source spend the time and $$$
to create a standalone system for this trans.
I am sure people will come out with programming for cars/trucks that
have the 6L80 from the factory to adjust for a stall converter etc.
but that is about it.
The trans should hold plenty of power though.
Old Jun 7, 2007 | 01:11 PM
Mike1234's Avatar
So if I want a 6L80... I must transplant the works... engine, transmission, computer(s), sensors, etc. Hmm... not really in my budget
Old Jun 7, 2007 | 03:26 PM
ChocoTaco369's Avatar
Tech Resident
it would be more trouble than it's worth at this point. no one has any idea how to do it. while it would be nice to have an A6, it's just not a viable option at this point in time. if you want an overdrive transmission that'll take whatever you can throw at it, the 4L80E is your answer. it's not a straightfoward swap, but it's very doable. i believe FLT has built a 4L80E that is taking 1000rwhp like a champ in one of their project cars.
if you want more gears, you could always run a TH350 with a gearvendors overdrive, but it'll be a costly setup and cause a lot of parasitic loss (the gearvendors overdrive is like having another tranny sucking up hp, which is why i said TH350 instead of TH400 because it sucks up less power). it would be kinda like having an A6 though...
Old Jun 7, 2007 | 06:39 PM
95ttoplt1's Avatar
Sounds like my SRT-8.
Its these CAN-BUS systems and they are a PITA and a POS. For some reason everything has to talk to everything. Seems like the A/C has its own computer that talks to the tail lights which relays the message through the sunroof control module to decide when to shift. Very complicated and no reason to be really.
Old Jun 7, 2007 | 06:59 PM
mr2guru's Avatar
Yeah... but now I can program my power window button to pop my trunk!
Old Jun 7, 2007 | 09:05 PM
Mike1234's Avatar
^^^ You guys are funny, LOL... but umm... sadly, you're right... ^^^
Old Jun 7, 2007 | 09:10 PM
LS1Tech Sponsor
It truly is amazing how many systems seemingly unrelated do interact with each other.
__________________
Call 888-744-6542
Old Jun 10, 2007 | 08:36 AM
spy2520's Avatar
if there are parts availaible...
Old Oct 2, 2007 | 03:31 PM
Circle-D's Avatar
I can build a converter for the 6L80. I have a few in Corvettes and am working on a truck version. I use a billet front with either a single disk or multi disk clutch.
Chris
Old Apr 11, 2012 | 08:24 PM
red 454's Avatar
old i know ,any upgrades yet
