SHIFT POINT PROBLEM
Old Oct 6, 2002 | 12:41 AM
CAT3's Avatar
Restricted User
Default SHIFT POINT PROBLEM
Ok, maybe i wasn't clear asking in the Copmuter section. At the track I hit my rev limiter tween 2nd and 3rd, not always, but on good runs I do. Would it be better to lower the line pressure setting for a quicker shift or raise the limiter?
2000 Z, A4, 3K yank, free mods, LCA's & SFC, no tuning at all.
13.4 @ 103mph, 2.0 60' street tires, not DR's.
Old Oct 6, 2002 | 11:06 PM
CAT3's Avatar
Restricted User
Default Re: SHIFT POINT PROBLEM
ttt
Old Oct 7, 2002 | 10:20 AM
Kristi's Avatar
Sorry, not an ECM wiz here, but I had the same problem with my first converter swap with stock tuning. I had good luck with simply raising the rev limiter.
Old Oct 7, 2002 | 09:33 PM
CAT3's Avatar
Restricted User
Kristi, I assume you used HPP3? How high to raise the limiter? Either way, thanks.
Old Oct 8, 2002 | 10:19 AM
Loco's Avatar
You can raise the limiter thru Hypertech or thru somebody like Ed Wright. Good luck.
