4.8 truck 4l60e into ls1 need help
Ok guys i already know i have to change end shafts so i can bolt my torque arm back up.And do i have to change shaft linkage because the ls1 4l60e is shorter?And should i chande out my speed sensor? And i will be using the torque convetor out of the 4.8 will it all bolt up to my ls1.And let me know if theres anything else i have to do before i can put it in. Thanks
