how to test converter and trans pump
Old Oct 7, 2002 | 10:38 AM
00NBMCamaro's Avatar
Default how to test converter and trans pump
i need to test my new PI converter to see if the pump is functioning correctly. also need to see how to test the trans pump and see if its working correctly..right now i have no car because of a converter **** up,
thanks
jeff W
Old Oct 9, 2002 | 07:49 AM
Ragtop 99's Avatar
Default Re: how to test converter and trans pump
If the pump broke, you can often look in the input shift area and see fragments.
If you think there is trash in the converter, send it back to PI for inspection.
