"Performance transmission fluid" worth the $?
Old Apr 28, 2007 | 11:45 PM
Bowtie Boy's Avatar
Default "Performance transmission fluid" worth the $?
Is this stuff worth the money? I was looking at Hurst Hot Shift fluid. Or is Royal purple better? IMO I would pick hurst over RP if this stuff works.
Old Apr 29, 2007 | 12:06 AM
ChocoTaco369's Avatar
Tech Resident
stick with CONVENTIONAL dexron III fluid. just get a brand like castrol or valvoline. it's all the same stuff. don't by synthetics. don't put fancy crap in it. put NOTHING but conventional dexron III fluid. anything else can decrease friction inside. this is a bad thing because it lessens the band's ability to grab due to the decreased friction. this results in band slippage and premature band failure. the end result will be a premature costly rebuild. no need for any trans additives, either. i believe the manual specifically warns against that.
Old Apr 29, 2007 | 01:16 AM
performabuilt's Avatar
LS1Tech Sponsor
any brand or type should be fine but as taco said just the regular stuff is fine unless you just like spending money
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
