Stall wont stall??? Why Fuddle 3800
Old 05-13-2007 | 06:49 PM
dpw41285's Avatar
93-vr4+transam sounds like were on the same page. I THINK its the gears. it stalls in town just not of the line. my friend had the same problem when he went to 4.11s he lost almost all of his 3600 stall
Old 05-13-2007 | 07:02 PM
spy2520's Avatar
Originally Posted by 93-vr4+transam
wow, that's pretty high, I can only brake stall my fuddle 3800 to around 2200 before the tires starts breaking loose.
i guess so, its the only stalled car i've ever driven so its normal to me. everything else about the converter seems to be on par with what everyone expects though.
and i just went out to check again, i definitely can put it right at 3000 on the brakes without it spinning.
Old 05-13-2007 | 10:49 PM
dpw41285's Avatar
quit rubbing it in....
Old 05-14-2007 | 01:00 PM
93-vr4+transam's Avatar
You must have higher gears? 273's or 323's
that is why Im thinking you can pull that high without spinning.
yeah dpw if we had 410 gears we wouldn't even be able to get as high as we are without spinning.... it's the gears..
Old 05-15-2007 | 08:15 AM
spy2520's Avatar
yeah i got 3.23s
Old 05-15-2007 | 08:32 AM
gold87TBI's Avatar
my fuddle 3800 2.2str also only foot breaks to about 2400 on slicks at the track but it flashes to about 4000 but i want for it to foot break to atleast 3400 or 3600 already had it restalled but still the same
Old 05-15-2007 | 09:09 AM
NC98Z's Avatar
Its also about how much HP your running. I have a Vigalante 3400 in my ride. When I first put it in It was installed with a small Crane cam and I didn't like the way it ran. It was way too loose for that cam. Later on I installed a TSP Torquer V2 and it was a different car on the highway. The cam complemented the convertor. Like 100 percent different.Now the car was fun to drive.
Old 05-15-2007 | 09:44 PM
GT Griller's Avatar
Well on a side note the more flash the harder the initial impact.
Old 05-21-2007 | 12:19 AM
dpw41285's Avatar
after this weekend of tuning, the conclusion is the gears and a tight str...stock cam and heads. I will wait it out and prolly have it restalled 2.5str
Quick Reply: Stall wont stall??? Why Fuddle 3800
